Caliper rebuild service
  • Todd Black 88
    • Oct 2007
    • 3449
    ATE/Girling/TRW/FTE Rebuild kits are 6-8 each and about 30 minutes of time to rebuild each. NuGeon Rebuilt calipers are 40 each + exchange +shipping if applicable. I don't see how it's more cost effective if one is doing everything themselves.
    Originally posted by Cletonius
    Does the kit come with new slides too? I'd want new slides on my rebuilt caliper
    No, that's where the real cost comes in. Seal kits are cheap, but new pins and guides, possibly pistons, makes it not worth it.
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • acolella76
      • 2950
      No, seals only.
      OP I'd recommend doing the rebuild yourself. It only took me about an hour to do all four corners, and that includes the time I spent painting them...
      -Alex
      • reelizmpro
        • 9508
        Nope, but neither do NuGeon rebuilt calipers...
        "Guide bolts 100% tested for function, straightness and alignment"
        Personally, I wouldn't replace the caliper unless the piston was scored badly and needed to be replaced. At that point, it's probably worth it to just get a rebuild as the piston is a critical component. Guide bolts...not so much.
        88 M3 - LACHSSILBER/SCHWARZE
          • 34839
          I don't think Blunt's were as much as the NuGeons. they're also nicer too - I think they come with some sort of paint, the NuGeons are just bare steel and rust immediately.
          I've also had 2 sets of NuGeons seize up after a year or two. that cost me a set of cooked brake pads.
          I know they're easy to rebuild (I've done it before) but the cost difference isn't significant enough to me. Especially since the caliper also comes out of the box clean and painted, all I have to do is bolt it up. I don't know if they came with new guides - they looked new to me?
          • InuFaye
            • 2221
            Originally posted by nando
            You can buy them rebuilt for dirt cheap. Blunt sells some pretty nice ones.
            Its hardly even worth the time to diy, just pull them out of the box and throw them on the car.
            The HPS arent going to rip your face off, ever. Lol. By the time you've got them hot, they overheat and you'd be better off with bars of soap.
            HPS are a good street pad. They have good cold bite and don't dust up a storm like HP+ do.
            1986 Plymouth Horizon. Base.
              • 34839
              None of the sets i went through had any cold bite whatsoever.
              • InuFaye
                • 2221
                Plenty of cold bite on my evo and 328.
                  • 34839
                  maybe your definition of "cold" is different from mine. :p
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    PNW vs South Eastern US.....I'd say there is.
                    • TimKninja
                      • 2131
                      You can get rebuilds from Derpazone for like $50 a peice . Or any local parts store really. I would of rebuilt mine but my bleeders were both snapped.
                      All I've read are bad things on the Hawk HPS for this car , I got some StopTech Street performances for like $45 on the internets.
                      1985 325e M50TU(Sold)
                      1991 318is Slicktop (Sold)
                      1990 325is Brilliantrot S50/5 Lug Swapped.
                      1992 525i Manual shitbox Winter Beater
                      • inflectionpt
                        • Oct 2012
                        • 35
                        http://www.goldlinebrakes.com... I've heard others talk about this company but no personal experience.
                        • MrSlacker
                          • 2494
                          Dude rebuilt calipers are like $50 each! We dont even bother with rebuild kits anymore, not worth the time.
                          My Seller/Buyer Feedback
                          Performance Aftermarket Parts & Accessories
                          • Roysneon
                            • 4505
                            I rebuilt one of my front calipers and got one reman. Only did the rebuild on the one as I couldn't get both side e24 calipers through my suppliers. I then proceded to buy the wrong seal kits (Derp) thinking since I have e30 M3 suspension and brakes I needed the seals for the same, forgetting that I had gotten 635 calipers (Larger piston). So after all that I had spent like $40-$50 more on the reman caliper, not thinking of my time to fix my mistakes and then the thing rattled around because the guide pin bushings were worn to shit and I can't run rattle clips with my wheel setup.
                            Ended up fixing that with Turner brass guide pin bushings.
                            Basically, rebuilding them yourself isn't really worth it unless you just want something to do. Buying rebuilds saves you time and you get everything done for you, no messing around with broken/seized bleeder screws, etc.
                            Originally posted by mbonanni
                            I am a pursit now.
