M20 Turbo or.....
  • henryki
    • Jun 2013
    • 960
    M20 Turbo or.....
    So I've been thinking about doing a turbo set up on my m20 to make about 300-350whp.. but earlier today my buddy was telling me about a 5.0 swap. I was thinking about maybe doing a carbed 5.0 so I don't have to mess with an ECU blah blah blah.. Any Ideas? yes or no?
  • JCarp90
    • Feb 2011
    • 1759
    5.0s are for fags, man.
    • jaywood
      • Jul 2010
      • 4528
      Do you know how much power the 5.0's put out?
      • george graves
        • 20003
        m60
        Originally posted by Matt-B
        • e30lov
          • Jul 2008
          • 1597
          93 Fox body 5.0, 205hp/275tq at the crank. Not exactly huge numbers here, but from the sounds of you not wanting to "mess with the ecu blah blah blah" I would recommend going this route. Turbo setups are more involved then just strapping a turbo to your motor.
          `92 325 vert - `90 325 coupe `99 m3 - Instagram @e30L
          • dougie30
            • Apr 2012
            • 1708
            Would much rather have a turbo m20 than a big heavy slow ford engine everyday
            Sent from my SPH-L710 using Tapatalk
            M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
            • WarHammer 2/1
              • Sep 2013
              • 190
              How's the fit with the 5.0?
              • delamaize
                • Nov 2013
                • 1465
                Dumpster Fire Pilot
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  You realize tuning a carb is as hard if not harder than tuning with fuel injection, right? At least with the fuel injection, unless you are changing parts, it will just run without problems.
                  • codrum
                    • Jan 2011
                    • 279
                    m20s are abundant and easy to turbo with all the guides available here and e30tech. You can easily make that power with a typical setup - every step has been done before and is laid out if you research a little. The most difficult and most important part is tuning. whodwho has you covered on the hardware and there are plenty of MS configs/maps.
                    If you want something unique then it would make sense to do a v8 swap.
                    • henryki
                      • Jun 2013
                      • 960
                      Same guy who was telling me about doing a 5.0 swap works at a race motor shop and can hook it up with afr heads and any machining needed. He built a 5.0 with stock crank forged rods/pistons and afr heads. He's making about 400hp don't know about torque tho.. Don't know exactly how much he spent but for sure less than 3k
                      • henryki
                        • Jun 2013
                        • 960
                        • Pantless Spency
                          It's McRib time!!!
                          • Feb 2011
                          • 7283
                          turbo.
                          5.slow is not a very great v8..
                          but a 5.slow would be fun, and does have enough power to allow fun, and is very cheap.
                          with that being said, a stock m20 is also "slow" and also has enough power to have a lot of fun.
                          • Peattie
                            • Apr 2013
                            • 260
                            • cgk_iii
                              • Dec 2012
                              • 616
                              Id go with a turbo or N/A M20 any day.. ECU isn't THAT complicated once you dig into it. Im sure if you're mechanically inclined enough to do a 5.0 swap then im sure you can figure out how to tune with ms
