bolt remover
    bolt remover
    ...which bolt removers are made well enough to handle a broken stubborn m6 bolt?
    ...i've tried two different ones, niether have shave sharp enough edges to do the job.
      Is it broken off in something? If there's enough bolt protruding from the surface, try a stud puller.
        there wasn't to begin with...after drilling a hole in the center, it's farther in that it started. that could have worked though.
          Then just drill it out oversize, tap it, and use an oversized bolt.
            ...that'll be last resort. for now i have faith that i'm going to find something that'll bite that hard ass bolt...the drill bit wouldn't even cut. took me 20 min to drill 5-6 mm!
              Try a new titanium drill bit.
                X1 - Don't be cheap, buy a decent bit and you'll be amazed!
                  I recently had a problem...
                  I bought this to guide my pilot hole, works with bolts sheared above, flush, or below the surface:
                  Then I bought more cobalt drill bits, left hand drill if you can find them in the hopes that the bolt will unscrew itself during drilling from the vibration.
                  Then I bought these to extract the bolt:
                  The vibration for drilling for an hour or two loosened mine, so the extractors hardly even dug in when I twisted it out.
                  Hope this helps.
                  -Brandon
                  '86 325es S50
                  '12 VW GTI Autobahn DSG
                  '03 540i M-Sport (sold)
                  '08 Jeep SRT-8 (sold)
                  For sale:
                  S50 TMS chip for Schricks
                    Hope this helps.
                    ^That's exactly what i was looking for...graet info man, dudes...thanks!
                      GEt a left handed drill bit and it will drill it out for you. i did it today on a tranny pan bolt that someone broke.
                      1987 PRO-3 car /1990 325is (2.7i Concours)
