What to look for when getting an E30.
  • DahaiTX
    • Feb 2014
    • 6
    Hello everyone,
    I have run into an opportunity in purchasing a seond car as a project car. Hearing that E30 is a great reliable car from my co-worker who owns them, I was wondering what should I look for flaw-wise on these cars?
    Thanks for the help,
    Dahai
  • DahaiTX
    • Feb 2014
    • 6
    Does the rust mean that the car's rusted into the frame? Thanks a lot for the reply.
    • Sea Aych
      • Apr 2013
      • 767
      No, not necessarily..
      It just means you'll eventually want to cut and weld in a plate to stop it from spreading. A pain you can easily avoid.
      1988 Atlantisblau Euro/Japanese 325i Cabrio
      1989 Schwartz 325i - now M50 powered! - now very dead
      1998 Toyota 4Runner Limited - gone
      My 17,000km Big NA National Parks trip!
      • trippmann
        • Dec 2012
        • 118
        These what I've got from internet, hope it helps :
        check the obvious things... make sure everything inside the car works (buttons, windows, fan blower, AC etc..) If it has a sunroof, look for rust where the tracks are. Check the engine compartment for leaks, oil level & condition, straight frame, VIN # consistancy. Look in the trunk for water accumulation and the condition of the spare tire, also to see if the tool kit is complete and if there's any record of the last timing belt change. If all that checks out fine, take it to a mechanic to see if everything under the car checks out and get an abstract on it from the Ministry.
        BEFORE YOU SHOP...
        Before you decide to start looking at E30's, you must promise yourself that you will not be afraid to get your hands dirty. Even if you find a gem, there will be problems that you should tackle yourself. BMW's are no harder to work on then other cars, but repair shops love to overcharge you just because you have a German car. Make a commitment to buy a metric set of tools, a Bentley manual, and a few hours of your time to keep your E30 in tip top shape without breaking your wallet.
        If you cannot change your oil, replace a fuse, or tighten a bolt do not buy an E30 because the little things will kill your love for your E30 and your bank account.
        However, if you don't mind spending a few hours every once in a while working on you car, then owning an E30 will be a great (and cheap) experience.
        WHAT TO LOOK FOR
        The one thing I cannot stress enough is that low mileage E30's do not make the best buys for two reasons. First, the owners of low mileage E30's usually ask a premium (I will explain why it is a bad idea to pay a premium for low mileage E30's). Second, owning an E30 between the 100,000 mile and 150,000 mile interval can be extremely expensive. A lot goes on these cars in the 50,000 mile period. Why pay a premium for a car with 90,000 miles when you are 10,000 miles away from hell? It make much more since to grab a cheap e30 with 150,000 miles or more since the 100,000-150,000 mile problems SHOULD have been fixed. Please note SHOULD.
        So what is so bad about the 100,000-150,000 black hole I keep referring to? Well between 100,000-150,000 the following parts usually need to be replaced or repaired:
        Steering rack $ 500
        Control arms $ 500
        Driveshaft $ 800
        Radiator $ 250
        Brakes $ 500
        SI Board $ 250
        Timing belt $ 400
        Battery $ 100
        Clutch $ 800
        Various electronics $ 0-1,000
        Auto Transmission $ 1,000
        As you can see, stuff adds up very quickly.
        There are no guarantees that the previous owner took care of the 100,000-150,000 mile maintenance, or did the jobs properly. There is even the possibility that the car you are buying managed to crawl through the 100,000-150,000 interval with no problems. This could mean that you are gonna get hit hard with repairs in as little as a week!
        Luckily there is an easy way to see what you are getting into. GET THE SERVICE RECORDS! I strongly advise buying an E30 without the service records. If the owner did not take the time to document the work done to the car chances are he wouldn't take the time to make sure the work was done properly. There is also the possibility the owner had the car serviced at an auto repair "chain," or "mom and pop" mechanic.
        One of the worst things an E30 owner can do is to have their car serviced at a generic auto repair shop. BMW are special cars that need special attention from certified BMW shops or highly recommended local shops that specialize in high end cars. Using an automotive repair "chain" or a "mom and pop" mechanic can be murder on BMW's.
        KICKING THE FENDERS
        Here is a list of things to check for when you buy an E30.
        Exterior
        Check all body panels for damage or signs of repair. Look to see if all the VIN numbers match. Look for anything out of the ordinary. Aftermarket spoilers or bodykits can sometimes be used to hide dents or damage. Check the head and taillights for cracks or pits. Make sure that all the door locks work properly. Check all trim and moldings for signs of overspray from a possible paint job. The hood washers, bumper trim, side moldings, door locks, door handles, and wipers should all be a flat black. If these are painted the body color the car could have a cheap paint job. Ask the owner if it OK to place a piece of making tape on an inconspicuous spot. If the car has the OEM or quality aftermarket paint job the tape should come of with no drama. If the tape takes tape with it, the car has been to a cheap repair shop. Look at the tread life on the tires. Also inspect the rims for damage. I also suggest that you get down and look at the under side of the car. Check for rust on the floorpans, drivetrain, and exhaust.
        Interior
        Look closely at the seats. If the owner has seat covers ask to remove them. Reupholstering jobs run $ 500- $ 2,000 for the front seats alone, so make sure the interior is in satisfactory shape. Check the dashboard and console for cracks or signs of wear. The carpet should be in decent shape. Ask to pull back a section to inspect the floorpans for rust (The carpet easily pulls back in the rear of the cabin. Make sure all buttons work. See that all the lights on the instrument cluster light up when the key is turned to position 1 or 2, and go dark once the car is started. It is very common for people to disconnect or remove the light bulbs to hid problems. Be sure the radio, power mirrors, power locks, power sunroof, flashers, turn signals, brake lights, fog lights, headlights, interior lights and AC work.
        Engine bay and Trunk
        Inspect the engine compartment and the trunk for signs of repair (The carpet will need to be pulled back in the trunk). The VINS should be found on both front fenders. The rear fenders do not have VIN stickers. Inspect all shock towers for excessive weld lines as it could be a sign of repair due to an accident or collapsed shock tower. The engine should be relatively clean. Make sure there are no leaks coming from the headgasket. Inspect the dipstick for signs of coolant (this could mean a cracked block). Check the condition and color of all fluid containers.
        Test Drive
        Check for a rough idle, hesitation, and knocks. The engine should be pretty smooth unless it is modified by performance upgrades like camshafts. Make sure the car can pull to redline without drama. Make sure the shifting is smooth and swift (short shifters can feel notchy). Check for a hard brake pedal and smooth stops. The handling and ride should be up to usual BMW standards (stiff but sweet). Make sure the E-brake is tight and holds the car in place. Don't be afraid to drive it hard! BMW's are strong machines that can take tough love easily if well maintained.
        I strongly advise that you take your car to an independent mechanic for a check up before you buy. However, using these tips can eliminate problem cars right away and save you the $ 100 or so for a professional inspection.
        It's actually pretty simple...
        1. Choose the model you are interested in and set your price range.
        2. Search the local Classified and Autotrader for the model you are looking for in your price range.
        3. Inspect the car and ask the hard questions.
        4. Take the car to an independent mechanic for the final inspection.
        5. If everything looks good, buy it!
        Chain tensioner and profile gasket, those are the major things
        What color is the oil? ... any metal flakes in it?
        How does the car idle? ...
        does the car stay straight when you slam on the brakes and let go of the steering wheel?
        does the steering wheel turn when you go over potholes?
        any grinding or knocking (not ticking) in the engine bay?.. how about when you rev high then release?
        what happens when you slam on the gas then release?... any knocking sounds from the shock mounts?.. subframe?
        ABS kick in when you slam on the brakes?
        any play in the steering wheel? ...
        automatic or manual?.. if manual how's the clutch?... how easily does the car shift from 1st to 2nd without depressing the clutch?.. if you push gently it should be able to slide right in without any grinding.
        Originally posted by unloadedak
        It's brand new. I've gripped the shaft a couple times and that's about it.
        • flyboyx
          • 8371
          well, those prices above are including labor. if you want to buy one of these cars, you need to figure out how to do maintenance yourself. for example, the timing belt is listed at 400.00. you can do it yourself for about 20 bucks. however, you should replace the water pump(50.00) and the coolant(25.00) as well. so....the list above has good information, but don't buy an e30 if you plan to pay someone to work on it. buy a honda civic instead.
          Gigitty Gigitty!!!!
            • 34844
            ^ $500 for brakes and $400 for a timing belt? on what planet?
            • FLG
              • Sep 2011
              • 3165
              Basically look for a good solid car, i typically look for rust..thats my only deal breaker really. If its not rusted chances are it just needs normal maintenance depending on who owned if previously.
              Expect to replace all the bushings, fluids, all the mounts, the entire suspension, brakes, and most importantly the timing belt if you purchase a "project" or slightly neglected car.
              Good example, i picked up a 250k e36 compact to daily recently. Spent 600$ on the car, spent another 700$ on maintenance items. And for 1300 i have a car that should be great for quite awhile longer.
              Same goes for the e30, though an e30 that cheap will likely be a headache unless you just get a great deal. Parts are cheap for these cars, and any labor is generally simple and straight forward with the rear subframe bushings being the largest hassle.
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • ky0u
                • Dec 2012
                • 808
                Originally posted by trippmann
                Steering rack $ 500
                Control arms $ 500
                Driveshaft $ 800
                Radiator $ 250
                Brakes $ 500
                SI Board $ 250
                Timing belt $ 400
                Battery $ 100
                Clutch $ 800
                Are these including labor for work at a garage?
                I got my steering rack for $200, brakes $120 for rotors and $30 for pads, clutch for $150.
                Web Designer / Front End Developer
                My Portfolio & Website
                IG: @w_illriderz
                • bmoores
                  • 151
                  The one thing I would say is that even if you find a good car be prepared to spend money on maintenance. Some preventative and some out of necessity. These cars will be very rewarding with proper care and maintenance but they also require steady maintenance as well as having issues addressed as they creep up ........ which is most cases will be frequently.
                  17 Range Rover Sport SVR
                  14 Q5 TDI S-Line
                  ...on the hunt for another E30.
                  • KIRIEIW
                    • Dec 2012
                    • 3385
                    Check if every panel has the same vin number as the car. If the hood and 2 fenders have been replaced there's a chance of frame damage and/ or the radiator supports been tweaked. I Checked out 2 cars with with some sort of front end damage and the body ship did a crap job, otherwise appearing clean from the outside
                    1992 e34 Touring- S50 Swap
                    1992 325i-S50 Swap (SOLD)
                    1991
                    • Bearmw
                      • 1323
                      You could always buy a basket case and resto-mod it but you will pay. You will pay...with time and money. Did I say that again? What are your goals and mechnical aptitude? The bottom line is how much are you willing to work on it and how much money you have to put into it? As has been said many times before, get the nicest one that has the most things you already want on it. Rust is the number one problem.
                      • ParsedOut
                        • Sep 2005
                        • 1437
                        Holy contradictory Batman!
                        There is nothing special about BMWs, if you can get dirty you can maintain them just as easily and inexpensively as any other 25 year old car. Get a prepurchase inspection done if you're not confident in your own ability to find weaknesses. In the rustbelt, rust is a big deal. It pays to look at everything that is rubber and inspect the condition, all bushings, boots and belts. Does the steering wheel shake when you hit the brakes, those are your control arm bushings, almost always worn out.
                        Service history is good if you are lucky enough to have it, otherwise you'll need to use your own methods of deduction to determine if the car has been maintained. Big chrome wheels, a 12" subwoofer flopping around in the trunk and flame seat covers are a warning to run away.
                        A clean, STOCK E30 with no apparent maintenance issues is about the best you can hope for.
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          Although there is some useful info there, If I had to hazard a guess....Ur-anus !
                          Alice the Time Capsule
                          • Javier h
                            • Sep 2007
                            • 1189
                            Are you saying that $400 (including labor) for a timing belt is expensive?
                            • ParsedOut
                              • Sep 2005
                              • 1437
                              None of those prices are crazy if you're talking labor included, especially high end german shop labor like he suggests.
