Stranded!
  • bowtie2bimmer
    • 830
    #106
    Well I did (potentially). I haven't paid for it yet. I just talked to the shop about 20 min ago.Here is where I am at.
    Mine:
    6 ex valves
    3 in valves
    3 rocker arms
    12 guide rods
    Valve job
    Stem seals
    Resurface
    Replacement head:
    6 guide rods
    Cam
    10 rocker arms
    Stem seals
    Valve job
    Resurface
    They can use my cam if I decide to fix the new head...
    So ya... screwed either way
    Sent from my SCH-I545 using Tapatalk
    1987 BMW 325ic - Emma
    • kwill22
      • Apr 2009
      • 962
      #107
      We'll if you need it ASAP and have to get the new head shipped it looks like it'd be more advantageous to use the old one.
      Which shop?
      DENY IGNORANCE!
      Schwarz 325-totaled
      brilliantrot 318i-daily
      Originally posted by mkcman17
      don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
      • bowtie2bimmer
        • 830
        #108
        Tachyon
        • kwill22
          • Apr 2009
          • 962
          #109
          Ok. I had never heard of them before
          DENY IGNORANCE!
          Schwarz 325-totaled
          • bowtie2bimmer
            • 830
            #110
            New head is here... I took them both to Tachyon for inspection. Here are pics of the replacement head:
            Pitting on lobes plus the chroming is lower than the outside edges so it fairly worn.
            One rocker is from my car one from new head. You can see the top one has a smooth surface where it hits the cam the other has a dip
            • Stanley Rockafella
              • Aug 2011
              • 4062
              #111
              why is your head so filthy? sheesh!
              what oil are you running in there?
              • bowtie2bimmer
                • 830
                #112
                It'd 27 years old and like 5 owners... I'm certain it's probably had like 30 different oils ran through it
                • bowtie2bimmer
                  • 830
                  #113
                  Upon further inspection... look what I found
                  Here its off the car
                  The most impressive part is it separated then wrapped the gears around itself.
                  Here is my belt
                  All I can find on that gear is its the "intermediate shaft gear" what does it do?
                  • TurboJake
                    • 3780
                    #114
                    That's..... Strange.
                    The intermediate shaft is used for giving the timing belt a good angle for the camshaft and it also drives the distributor on older M20's. Not yours though. It also drives the oil pump IIRC. It's been ages since I've torn an M20 apart.
                    Well there's your problem!
                    Leave Me Transaction Feedback
                    • lukeADE335i
                      • Apr 2013
                      • 1389
                      #115
                      Yes - intermediate shaft sprocket failure. I've never heard of one of the sprockets failing before, but the intermediate shafts themselves can fail as they run in bearings that are milled into the block.
                      Take the sprocket off and see whether you can turn the shaft, you might need to investigate the oil pump etc. to work out whether the sprocket failed, or the shaft jammed (causing the sprocket to fail).
                      On motronic cars it drives the oil pump as suggested.
                      On L-Jet cars, it drives both the distributor & oil pump.
                      My e30: OEM+ with M30B35
                      • bowtie2bimmer
                        • 830
                        #116
                        Got the head back
                        • Swanny
                          • Mar 2012
                          • 2834
                          #117
                          Wowwwwwww!
                          Swanny!
                          SUCKERS.
                          • F34R
                            sLaughter
                            • 12376
                            #118
                            None of the intake valves got bent? nice head ;D
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                            • bowtie2bimmer
                              • 830
                              #119
                              3 intake were replaced... The three on the right side are new
                              • bowtie2bimmer
                                • 830
                                #120
                                Left side*
