Stranded!
  • bowtie2bimmer
    • 830
    #76
    Just landed at home.... Its been a long ass day lol
    Sent from my DROID RAZR using Tapatalk
    1987 BMW 325ic - Emma
    • lukeADE335i
      • Apr 2013
      • 1389
      #77
      Good to hear you made it home.
      If the motor is toast, the M50 or M30 will give you a timing chain. Both worthwhile.
      My e30: OEM+ with M30B35
      • bowtie2bimmer
        • 830
        #78
        Ok, here are the pics. Check out the score marks on the piston and i can clearly see one bent valve
        • bowtie2bimmer
          • 830
          #79
          Pistons seem to be good. The scoring is very minor once i cleaned the pistons.
          I think my major issue is a bent valve and 3 broken rocker arms
          • BobombETA
            • Apr 2008
            • 1575
            #80
            Doing work, have you sourced a head?
            Instagram
            Current: 99 M3
            Past: 84 325e, 84 528e
            • bowtie2bimmer
              • 830
              #81
              Yes, 2 actually
              • lukeADE335i
                • Apr 2013
                • 1389
                #82
                Sounds like you'll be fine with a new head. I've pulled a part plenty of M20s over the years where the valves have clearly hit the pistons & marked them, but it's caused no major concerns & the M20 has obviously powered on after that just fine.
                • 15Michaeljoseph
                  • Aug 2013
                  • 1693
                  #83
                  It always impresses me how bulletproof these engines are, so long as the timing belt is there.
                  --sent from my igloo via carrier penguin
                  (OO=[][]=OO) For Life
                  • bowtie2bimmer
                    • 830
                    #84
                    Ok, do i need to do anything to the head before i install it? I heard that all heads should be resurfaced before install?
                    • flyboyx
                      • 8371
                      #85
                      hell yes it should! don't even think about putting it on without doing that first. in fact, why wouldn't you want to get the valves redone before you slap it back together. it will run like a new car. you have already done 80% of the work anyway. just take your time, spend the money, and do it right. you will be really glad you did.
                      while you are at it, replace all your rubber hoses and belts.
                      you are already doing it yourself, so you are saving probably 1200.00 in labor. use some of that money to do it right!!!!
                      Gigitty Gigitty!!!!
                      • Ether-D
                        • Sep 2011
                        • 2838
                        #86
                        If you have the money to resurface it, it's worth it (<$100). If not, check it for warp with a straight-edge and go for it.
                        Originally posted by Andy.B
                        I was born on 3/25…
                        • KIRIEIW
                          • Dec 2012
                          • 3385
                          #87
                          Damn man I'm sorry to hear all of this. If it happened to me, I would go the same route as you and get the car running again, and by the looks with the same m20 bottom end. Anyway, was the result from a snapped timing belt after all or did is skip a couple teeth? Regardless if it did snap Id be interested in the brand.
                          -Kevin
                          1992 e34 Touring- S50 Swap
                          1992 325i-S50 Swap (SOLD)
                          1991
                          • bowtie2bimmer
                            • 830
                            #88
                            The problem is its my daily, i need it sooner rather than later. The new head is clean... In a perfect world i'd like to do valve stem seals and new springs,
                            • bowtie2bimmer
                              • 830
                              #89
                              -Kevin
                              Belt didn't break but started to sepeeate. I think the tensioner may have been out of round causing uneven wear. It was the belt and tensioner kit from Continental
                              • 15Michaeljoseph
                                • Aug 2013
                                • 1693
                                #90
                                ...Which is no longer manufactured in the USA :(
