Fast 318is Nürburgring in 9 minutes
  • Massimo
    • Jan 2008
    • 3207
    #46
    Originally posted by word is bond
    Write-up on Pistonheads:
    The difference between owning a car and loving one? Dale's new purchase could be the perfect example
    m44/m42, cams, exhaust, etc. less than 2200 lbs.
    Dam this inspires me to do the same with my car.
    • Eric
      • 5142
      #47
      9 minute BTG times is quick, but not something to change your underwear over.
      Where the driver passed the second porsche, is a part of the track called foxhole, it's steep downhill, then steep uphill. An in-experienced driver would lift going down because the road is bumpy and scary, but he stays flat, that is why he is able to pas the p-car so fast. My MINI clubman S on KWV1's and 195/50/15 ToyoR888's ran an 8:45ish GTG, and it's speedo indicated 140mph through this section...
      The E30 driver keeps his corner speed up through the Adenau Forst section, tracking out on the line to the left of the M3. I didn't notice if the M3 had a bad line or moved right for the E30, but the E30 carried way more exit speed than the M3, that's why it doesn't seam like the M3 has the balls (we know it does) to pass the E30. The M3 gives up first and lets him buy, which is common in europe.
      • LJ851
        • 7919
        #48
        I called it.
        Lorin
        The M30 is God's engine.
        • Delta
          • Oct 2014
          • 34
          #49
          Still like this video, weight and balance are just as important as power
          • word is bond
            • Apr 2012
            • 503
            #50
            If you go into the pistonheads comments, there was apparently a 2007 article about a stripped 318is that could do 8:20 on stock power. I'm skeptical. Someone posted pictures of the article in the first comment, but they got taken down before I could read it.
            diamantschwarz 1991 318is
            • elbrack
              • Jul 2013
              • 176
              #51
              Originally posted by QUKBMER
              It does sound like a S42 swap. For those of you that watched and know old school BTCC from the mid 90's,you know that sound.
              That is the engine I would love to recreate.
              • Alpina
                • Oct 2004
                • 838
                #52
                Here is an epic video of an E36 touring car with that engine
                stunning how fast the car is
                Sveinbjörn Hrafnsson
                E30 CABRIO V12 M70B50 ///
                ALPINA B10 BITURBO 346 @ 507
                E34 550 V12 JML
                Finnish wisdom : If you want to Win,, hire a Finn
                http://alpina.123.is/pictures/
                • Eric
                  • 5142
                  #53
                  My fastest recorded (iPhone timer) lap was btg 8:22 in my e30 with a stock m20 pulled from a junk yard.
                  John Johnson (red 2.7l m3, s14power guy) told me about a German old timer that could do sub 8 min laps btg in a m20 powered e30. This old timer claims that you only need to break times on the track!
                  The m42 is what 30hp down on the m20? I bet with less weight and a better driver than me, a 8:20 laps is definitely feasible.
                  • E30 Wagen
                    • Jul 2005
                    • 3432
                    #54
                    John Johnson (red 2.7l m3, s14power guy) told me about a German old timer that could do sub 8 min laps btg in a m20 powered e30. This old timer claims that you only need to brake ? times on the track!
                    How many times? I wonder how a standard 2.7i build would perform.
                    My Feedback
                    • animal
                      • Jan 2010
                      • 804
                      #55
                      Wow. Once again its all about a crazy good driver! M42 POWA!!! Love it.
                      91 DS S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Bahama Beige 323i, M535, Euro e24, ap1
                      www.RenownUSA.com
                      ig @RenownUSA / @rude.scott
                      • animal
                        • Jan 2010
                        • 804
                        #56
                        Love hearing about your experiences on the ring! Still got your lime green turbines too!!! ;)
                        www.RenownUSA.com
