Wheel polishing lathe
  • Kershaw
    • 11822
    I wanted to polish the lips on my RS before they get new tires. I was considering rigging up the motor and belt drive from either my old table saw or planer, but then I thought, "hey, I already have a spinning hub perfectly built for rotating these rims." I jacked my ix fully off the ground, put it in 3rd, and let it idle. Dangerous? Yeah, maybe. Effective? Yep, definitely. Used 1500 grit wet sand. I should have removed the tiny bolts, but retorquing all 120 is a pain. I might do it the next go around in 2 years though.
    AWD > RWD
  • Mr. Tasty
    • Jul 2011
    • 3421
    I like it. Work smart, not hard.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
    • TobyB
      • 5298
      ...and don't stick your finger in there!
      hee
      t
      • LateFan
        • May 2013
        • 4436
        Didn't leave a million parallel scratches on there?
        • Mr. Tasty
          • Jul 2011
          • 3421
          wet sanding with a fine grade (1500+) sandpaper?
          (Daily Driver)
          KW V2 Coilovers
          • ThatOneEuroE30
            • Dec 2013
            • 8626
            Lol sweet should finish with 2000 grit and then get a polishing wheel for a cordless drill or angle grinder and some compound and make them bitch'ss shine! then do the final polish with aluminum polish like normal what i did with my oz turbos and its incredible
            Here how mine finished
            1991 318i 4dr slick top
            Mtech 2 turbo restoration
            • ST1G
              • Oct 2012
              • 6690
              Hmm, pretty good results. Didn't catch a finger did you?
              Bro, punctuation matters.
              • straight6pwr
                • Sep 2004
                • 3450
                i rigged up an old bench grinder motor to my style 5s, but I would do it your way the second time around. not enough torque to keep em spinning when applying pressure to do the sanding. i did remove the bolts so that the finish would match behind them, then used double stick tape to hold the face to the lips when spinning.
                • ThatOneEuroE30
                  • Dec 2013
                  • 8626
                  For that st1gy. I give you this badge
                  • Kershaw
                    • 11822
                    I have 2000 grit, but I wasn't going to take the time for another round of sanding with the bolts still in there. I will give it a swirl with a drill powered polisher abs aluminum polish once they're installed.
                    AWD > RWD
                    • BillBrasky
                      • Dec 2008
                      • 1641
                      Here's an instructional video if you want to take your lathe to the next level or if you've just had a few Molsons and want some old fashioned Canadian entertainment.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        I did the same thing with a set of E21 weaves I put on a MK2 jetta I had. Used a grinder with a flap disk first to take off all the rash, then sanded them nice and smooth. Worked great.
                        • DER E30
                          • Sep 2013
                          • 2349
                          I'm gonna do this in a few weeks when I get new tires. Gotta take the old ones off or pull the valve stems though. The last time I tried it the valve stem came around and beat up my fingers, every stupid rotation...:( I hit the PO's curb rash good though!
                          3rd seems like a decent gear, and if the jack drops it or whatever, the m42 has no chance in hell of moving the car anywhere
                          -Christian
                          • e30m3s54turbo
                            • Jun 2010
                            • 3295
                            I polished mine by hand. At the final it was 2000 grit.
                            • LJ851
                              • 7919
                              I did a similar thing.
                              Lorin
                              The M30 is God's engine.
