Double turbo blower v8
  • ncsubowen
    • Nov 2013
    • 1012
    Stop downplaying the idea - load yourself up with a fire suit and extinguisher and give this shit a shot - at the very worst you set your car on fire, and at best you develop a balls ass crazy jet powered turbo setup that is hilariously awesome.
    4 doors.. so much room for activities!
    IG @bluebombr
    Transaction Feedback:
    http://www.r3vlimited.com/board/showthread.php?t=323622
    • jalopi
      • 2370
      Originally posted by mrsleeve
      Why not just put a blower on it and stop over complicating the problem . It gives you the space savings you need and NO LAG........ Plus the parsitc drag you lose is not going to be enough to worry about your building a street car not a all out ever last oz of performance engine here
      good question - you make a valid point, but i won't be able to do the v8 swap for another two years due to emissions reasons, so in the meantime i can turbo the m52. i know that sounds really stupid, but all the state wants to do is plug a scanner into the car and make sure the VIN pulled up on the computer matches the one in their records. after my last emissions test i can finally put historic plates on my car and never worry about that again.
      also, technically, this idea is actually better at lower revs than a supercharger. think about it this way - here's a before/after dyno graph of a 350z after installing a supercharger.
      notice how while the supercharger still has a linear power curve, it doesn't quite follow the same curve as the stock engine? i mean, it obviously can't since it's output is dependent on engine RPM, only not as much as a turbo's. notice how it goes from an initial 10% increase in power to a 45% increase? obviously it takes some RPMs to get the blower up to its set boost level (which is probably about 7psi based on the power increase)
      my proposed setup, in theory, would be a 45% power increase across the board since full boost levels would be available at any engine load or operating speed. as a visual, here's the same dyno graph, edited to show stock vs my setup at the same boost settings (queue more shitty art skills)
      you can see how at a constant 45% increase in airflow there is a tremendous difference in power. essentially, it's almost like you took the OE power curve and dragged it up on the graph. i mean look at that shit... that's practically a stock ls1 torque curve / ft/lb level
      maybe i'm doing something wrong with my estimations, but i'm pretty sure this would work as planned
      • pandaboo911
        • 2070
        So you're getting rid of the boost lag with a crazy turbojet and then putting it back with a remote mounted turbo.
        Facepalm
        • jalopi
          • 2370
          1. remote mount turbos aren't as bad with lag as people make them out to be
          2. theoretically, i could have this turbo setup on a trailer 30 feet away from the throttle body and there still wouldn't be any lag. the cold side pipes are being constantly pressurized. like, to the point where when the throttle is closed the BOV starts releasing a gale-like force of air
          basically there won't be any lag, period
          • IronFreak
            • Dec 2012
            • 3702
            Just 6-7 50mm BOVs.....
            Instagram @rebellionforge
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4501
              Keep in mind that is a centrifugal type blower, which isn't very efficient down low. If you run a roots type blower, your low end is going to increase to the level that I think you're hoping for if you do it right.
              • jalopi
                • 2370
                vented through the hood
                • IronFreak
                  • Dec 2012
                  • 3702
                  make um all HKS SSQV BOV's.....everyone in a 5 block radius would hate you. would sound like 5000 little squirrels all getting gang raped at once.
                  • TobyB
                    • 5288
                    That's what some of the anti- lag systems do, but they use the primary turbo. Add extra fuel,
                    a way to light it in the exhaust manifold, and viola, you have a small turbine engine under your hood.
                    At that point, though, why not just go full turbine engine and get rid of all
                    those messy pistons and valves?
                    Because, shit, under the hood will start to look like an exploded plumbing experiment gone bad...
                    t
                    • LJ851
                      • 7919
                      This is what you need.
                      Lorin
                      The M30 is God's engine.
                      • flyboyx
                        • 8371
                        somehow:
                        reminds me of:
                        Gigitty Gigitty!!!!
                        • flyboyx
                          • 8371
                          other than that, i think this must be the greatest idea i never thought of.
                          Gigitty Gigitty!!!!
                          • mrsleeve
                            • Mar 2005
                            • 16387
                            there is more than likely a very good reason you have never thought of it........
                            seems like slightly better idea than this
                            Originally posted by Fusion
                            William Pitt-
                            • jalopi
                              • 2370
                              omg that is so cool, too bad it's probably only a few steps below a top fuel dragster when it comes to fuel consumption
                              • 4x4_e30
                                • Sep 2013
                                • 164
                                Check out how the new Formula 1 turbos work.
