Found this under valve cover.
  • roguetoaster
    Biggus Tippus
    • 7830
    Originally posted by dude8383
    Dude. Thats your upper timing chain tensioner and it appears to be fucked lol.
    You will definitely need to replace that.
    It's not a tensioner, just a guide. It's also non essential to engine operation.
    However, it is usually the last M42 timing system part to fail, and since it's gone then I would urge you to overhaul the entire timing system. Get a new deflection wheel too, or convert to an E36 timing case.
    • TobyB
      • 5243
      It usually breaks right about the time the plastic lining sheds off of the tensioners and guides,
      and then jams itself under the timing gears causing the chain to skip teeth.
      When I changed the tensioner slider on mine, the plastic peeled off of it with a gentle tug.
      jus' me,
      t
      • BobombETA
        • Apr 2008
        • 1575
        How's it running? Sound like a misfire at all?
        Instagram
        Current: 99 M3
        Past: 84 325e, 84 528e
        • Th3importedguy
          • Mar 2014
          • 190
          It ran perfectly fine until my head gasket blew
          E30 is life :finger:
          • Dj Buttchug
            • Jun 2010
            • 7672
            Op you dont need the top guide. just DGAF bro
            Turbo M42 Build Thread :Here
            Ig:ryno_pzk
            I like the tuna here.
            Originally posted by lambo
            • Th3importedguy
              • Mar 2014
              • 190
              Exactly what I was thinking lol
              • Massimo
                • Jan 2008
                • 3207
                This
                • DER E30
                  • Sep 2013
                  • 2347
                  Originally posted by Th3importedguy
                  I can't piece it together to make anything.
                  Zip tie and JB weld skills are lacking
                  -Christian
