Let's talk fire extinguishers.
  • jhaurimn
    • Nov 2012
    • 2224
    I have one in the m3 and I just leave it in the pass seat or the rear seat. Never moves around, even when throw I throw the car around corners.
    Just make sure the one you buy is rated to handle gasoline fires.
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
    • e30onBBSs
      • Dec 2014
      • 1347
      I'm not sure where to buy this part and it may be too hoon but I honestly don't notice it, its situated behind the e-brake. PO's funny sharpie shit and I added the m20 love. There is a plastic thing that grabs the neck of the extinguisher securely and holds it in place with no movement
      BMW tech
      Umass Amherst
      05 wrx sti
      • Wschnitz
        • 8089
        I Bet you could fit on in the armrest of the rear seat if you hollowed it out. Then you could flip it up and not see it, but still flip it down for easy access.
        willschnitz
        • imjusthere
          • Jul 2014
          • 119
          Had two engine fires recently. A couple guys put out the second one with your standard extinguisher (a, b, maybe c) and it corroded the hell out of everything under the hood. I'd look into a halon one if you really care to save your electronics.
          Sent from my XT1254 using Tapatalk
          • jhaurimn
            • Nov 2012
            • 2224
            If your car is on fire, I think corrosion is the last thing on your mind. The whole point is to stop the fire from claiming the entire car.
            Good point, though.
            Current:
            1989 325i
            1988 M3
            1987 325ic
            Past:
            2001 330ci
            2001 M3
            • imjusthere
              • Jul 2014
              • 119
              Good point, though.
              I put the first fire out with water and there was very little damage. The one with the extinguisher ruined everything. I wouldn't spray another one on my engine unless it was a halon.
              • Cephas
                • Apr 2012
                • 878
                Originally posted by ak-
                I keep it loose behind my seat.. I'm tall with the seat adjusted all the way back - it's not going anywhere.
                Im not that tall but I do the same thing with my Autozone model. I also have my seat pretty much all the way back because no airbag.
                • TobyB
                  • 5293
                  see the difference of how stubborn a hot surface fire is - it's a big change.
                  This, for sure. The CO2 version helps a lot with a 'small spark, lots of heat' because it
                  gets the heat AND the oxygen out.
                  Because those damned powder ones are great if you're gonna die, but suck if it's just
                  a small fire under the fuse box.
                  t
                  • Rocla
                    • 922
                    Originally posted by AlonzoS
                    Really interested in how this one was mounted under the front seat. SoCal323i's car really inspired my build and would love this.
                    Bracket is bolted to seat frame with 2 bolts.
                    Current:
                    BMW 320i 2d 2.0 m20 -88
                    BMW 325i Cabriolet 2.5 m50 -88
                    BMW 316i touring 1.6 m40 -90
                    BMW 320i 4d 2,2 m54 -01
