Dynod my 325IS
  • mtechnik
    • 6156
    well seems like you bough the right E30 Ddongbap !
    @ Sean , thanks for the formula.
    Im kinda scurred bout dynoing my car in a case I get disappointing numbers.
    To me....it seems like the motor still pulls strong
    • King Luis
      • Sep 2004
      • 737
      Originally posted by PeaveyBassist
      I believe 1990 and 1991 cars were limited around 125mph. Its totally possible that it is really 115mph as well because the speedo will be off a little bit. I thought our's always read a little high.
      Will
      i have a 1990 325is and my car has yet to top out. our cars are basically gear limited when it comes to top speed. they are also held back by either power and/or aerodynamics.
      i like those numbers. i'd like to do a base run on my car one day.
      • Digitalwave
        is a poseur
        • 6296
        Nice numbers. Your car puts out more to the wheels than an M42 or an eta to the crank ;) (I am sure Josh will reply to this.)
        RISING EDGE
        • ddongbap
          • Sep 2005
          • 248
          Lol.
          Okay, well based on the dyno numbers, would a compression test be worth it? Or am I in a safe zone?
          My drinking team, has a racing problem.
          Anyone have an aquarium? If you want fish, let me know.
          • mspiegle
            • 1026
            Originally posted by ddongbap
            Lol.
            I would say your safe, but compression/leakdown numbers would just add some good info for future reference.
            Michael Spiegle
            '01 Ford Escape / Daily Driver
            '99 M3 / Track Car
            '87 325is bronzit / wtf car
            '06 Daytona Triumph 675 / Daily Rider
            • netcsk
              • Apr 2004
              • 1609
              '88 and up had a speed limiter. If you look at ETMs you'll see this.
              It is easy to bypass. We had this discussion on roadfly a few weeks back.
              It routes through pin 14 of the C101 fusebox connector. Pull pin 14 out of the engine side of the C101 connector, should be a white and black wire, fold it back over itself and tape it up. Wallah, you can get a few more mph till it tops out.
              135mph is higher than the limiter should be anyway. So maybe your car is an 87 or early prod. 88?
              • ddongbap
                • Sep 2005
                • 248
                Nah, its a 90. I haven't taken the car down a freeway past 110. But the dyno hit 135 before my friend let off.
