NOTE: Please take the time to read this. Even if you can only give advice or insight to one of the issues, it'll be that much closer to smoothing out the bumps.
As most of you know, I'm 2 weeks on the road with my m20 stroker vert. As one should expect, there are still some bugs that need working.
First off, the rear subframe bushings are non-existent. I need to replace them, but don't want to make the ride too stiff. I'm running H&R race w/ bilstein sports, and moving from a 14" tire to a 16". Will urethane be a bit too much, or will it be a welcome upgrade?
Second, there's been an ongoing issue with puffs of smoke coming from my rear right corner. When people are following me on the highway, they see it - definitely out of the RH side, and it was doing it before the swap. It's not exhaust related, as far as I know, so I can't figure out where it's coming from. Seems to happen when I hit bumps on the highway, if that helps. Also seen when I cornered hard left once or twice too.
Next, my fuel cutout issue. Came back again today, but again, not consistent, and can't find the cause. Driving down the highway and the engine cuts out and in again, and eventually stalls out. Turn the key off and on, and it's back to normal for a bit. I can get in the car a few hours later and it won't do it even once. Theories are a bad ecu, bad tps, bad relays, or a possible bad fuel pump. Thoughts?
Lastly, a heck of a rattle when idling, that's now also rattling when accelerating in 1st and sometimes second. Push the clutch in at idle and it goes away. Shift past second or third, it goes away. Doesn't do it all the time when accelerating, but always at idle - might be two seperate issues.
In any case, I can't afford one more day without this car, so I've got to get in there on Wed and fix any and all of these before it leaves me stranded.
