Looking at a car with a snapped timing belt
  • anabolice30
    • Jul 2013
    • 946
    So as the title says, there is a 1988 325is and the owner claims the car has a snapped timing belt. Says he bought it like that.
    I know when a timing belt it can damage the valves, but I'm unfamiliar with the guts of an m20, and I'd like to know what exactly I should be looking at. I'm prepared to put a new engine in, but if anything this should help me knock a few hundred dollars off the price point.
    So if someone has a picture lying around of bent up m20 valves I'd much appreciate it, google images yielded very little. Thanks!
  • Todd Black 88
    • Oct 2007
    • 3449
    New head
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • 2mAn
      SeƱior Mod
      • 21049
      Buy car for less than a grand, spend a grand on a Bimmerheads 885 and you will be a happy man
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • AndrewBird
        The Mad Scientist
        • 11898
        If they timing belt snaps, there is no might bend valves, you WILL bend valves.
        As others have said, new head at the very least. If a valve head broke off and bounced around inside the cylinder, then you need a new engine. Good time for a 24v swap.
        • 2mAn
          SeƱior Mod
          • 21049
          go into it expecting to have to buy a new motor, and definitely negotiate it that way. If he has the head off, then it might be harder if the bottom end looks nice, but either way...
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • e30onBBSs
            • Dec 2014
            • 1347
            once you buy it pull the head first obviously before you buy a new one. My friend snapped his t-belt and shattered a piston... it can be real bad. GL!
            BMW tech
            Umass Amherst
            05 wrx sti
            • 101
              • Jul 2011
              • 764
              I agree with everything above.
              Even at a low RPM timing failure and if the bottom end turns out to be OK, the force from the valves can break rocker arms, cause cracks in the rocker shaft and camshaft journals, bend rocker arm shafts and valve guides, etc. Always plan on at least a new head, and maybe on a replacement motor. You won't know until the head comes off what you'll be facing.
              101
              The E30 collection:
              1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
              1987 325is - Delphin / Black Sport (son #3's)
              1987 325i Convertible - Triple Black
              1989 325iX Coupe - Diamondschwarz / Black Comfort
              1990 325iX Coupe - Sterling Silver / Grey Sport
              1981 Fiat 124 Spider 2000 - Green / Tan
              1998 Volvo V70 GLT - White / Tan
              1998 Volvo S70 T5 manual - White / Taupe
              2001 Ford Windstar - Silver / Grey (parts hauler)
              2006 Lexus GX470 - White / Tan (tow rig)
              • TobyB
                • 5296
                You're looking at a car without an engine.
                If, when you get in, you find usable engine parts, bonus.
                t
                • agent
                  Vice Grand Pubaa
                  • 7960
                  This. I'm sure RobertK has an engine or two around there.
                  Originally posted by kronus
                  • Jon325i
                    • 6934
                    A snapped timing belt could involve more than just bent valves. What condition are the pistons in? My last E30 was sold as a project car because when the T-belt snapped, a visual inspection showed a chunk of a valve embedded in pistons 2 and 4. In my situation a full engine rebuild was needed. This may not be the case every time, so thoroughly inspect what you can before making an offer. The last thing you want to find is more 'surprises' after you remove the head.
                    By the way, no fancy tools were required - just pull all the spark plus, put a large wrench on the crank hub, and slowly rotate. Use a small flashlight or probe light to see what's happening inside.
                    Jon
                    Rides...
                    1991 325i - sold :(
                    2004 2WD Frontier King Cab
                    RIP #17 Jules Bianchi
                    • anabolice30
                      • Jul 2013
                      • 946
                      Thanks for all the info guys. Yea I figured new engine would be in order. Would not mind throwing a 24v in, or an m30, which is my dream swap.
                      • ThatOneEuroE30
                        • Dec 2013
                        • 8626
                        Originally posted by anabolice30
                        Thanks for all the info guys. Yea I figured new engine would be in order. Would not mind throwing a m30 in which is my dream swap.
                        I agree with this please buy and do this swap
                        1991 318i 4dr slick top
                        Mtech 2 turbo restoration
                        • anabolice30
                          • Jul 2013
                          • 946
                          Only if I'm promised financial backing in exchange for 30 minute "joy rides"
                          • aegul44
                            • Apr 2015
                            • 396
                            If I were you, I would remove the head and see the damage. Tell her car needs new engine, lower the price, swap new engine.
                            Esquire E30 Build (87 325i Vert)
                            Ultimate Tanning Machine
