Can someone find me pics of an e30 on japan racing jr 10s?
  • MTD
    • Nov 2015
    • 112
    Hey guys. Just wondering if someone has pics of a set of jr10's on an e30. Been searching on google a lot but haven't found anything decent. Preferably the silver ones!
  • jaywood
    • Jul 2010
    • 4528
    Scroll down on this page: http://bmwbuilds.com/e30-track-prep-supercharged/
    • MTD
      • Nov 2015
      • 112
      Originally posted by jaywood
      awesome thanks! he is running 32mm spacers, do you think an et10 wheel without spacers would sit flush with the body? I can't legally have the wheels "sticking" out of the body of the car
      • varg
        Florida Turbo Man
        • May 2014
        • 3431
        What size? 15x8 ET10 wheels won't need spacers. Neither will 16x8. Mine were a close fit and are ET20. There is a thread for wheel fit questions and the exact spacer info you need is probably in there, just search ET10 and comb through the results. For what it's worth, my 16x8 ET20 wheels and 225/45/16 tires fit just under the front arches, so you shouldn't have any trouble there if your wheels are narrower. Rear arches required rolling.
        IG @turbovarg
        '91 318is, M20 turbo
        • MTD
          • Nov 2015
          • 112
          Originally posted by varg
          What size? 15x8 ET10 wheels will require a spacer up front, 10mm or more. I'm almost certain 16x8 ET10 will as well, mine were a close fit and are ET20. Not sure about the rear but I'm guessing spacers will be required there too. There is a thread for wheel fit questions and the exact spacer info you need is probably in there, just search ET10 and comb through the results. For what it's worth, my 16x8 ET20 wheels and 225/45/16 tires fit just under the front arches, so you shouldn't have any trouble there. Rear arches required rolling.
          damn, so even with et20 you needed rolling? I will definitely need rolling if i go et10 right? My car is lowered on vogtland springs though, not that much of a drop
          • varg
            Florida Turbo Man
            • May 2014
            • 3431
            I got mixed up on the front, ET10 is 10mm further out than ET20 not 10mm further in. Your ET10 wheels won't need spacers then because they are further from the strut and spring, but if they're 8" wide they will definitely stick out past the arches. Yes, you will need to roll the rear. Any drop is too much, since at stock height mine rubbed when the suspension compressed and yours would be further out. That is unless your wheels are narrow. Again, this all depends on the dimensions of the wheels, which you haven't given us, I'm just making assumptions based on the measurements I found for those wheels when I googled them.
            IG @turbovarg
            • MTD
              • Nov 2015
              • 112
              Sorry, the wheel options i'm considering are:
              1) 16x8 et10 front+ 16x9 et10 back
              2) 16x8 et10 all around
              3) 16x8 et20 front + 16x9 et20 back
              4) 16x8 et25 front + 16x9 et20 back
              5) 16x8 et25 all around
              any of these would allow me to not roll the fenders?
              • Wschnitz
                • 8089
                16x8 ET20 square would probably fit no rolling and no spacers. Assuming you do 205-50 tires.
                willschnitz
                • JinormusJ
                  • 6887
                  Not sure why you're against fender rolling?
                  • MTD
                    • Nov 2015
                    • 112
                    Sorry , what does et20 square mean?
                    I'm not against it, i simply don't know where to do it, nor anyone that has done it... I'm in Europe.. I'll try to ask around, but it may be tricky to find someone who can do it for me
                    • JinormusJ
                      • 6887
                      et20 specifies the offset and squared just means that all wheels are the same size/dimension/offset as opposed to staggered which has wheels in the rear that are different/larger in offset and dimensions than the fronts
                      Due to the nature of BMW rear suspensions, the rear wheels typically can and mostly do run wider with similar but varying offsets to allow for wider tires and better traction
                      However; many opt to run a square setup with possible spacers to mimic a staggered setup for the simplicity of being able to rotate front and rear wheels in order to preserve tire life
                      • MTD
                        • Nov 2015
                        • 112
                        nicely explained thanks!
