Changing oil in low cars
  • stillkotd
    • May 2011
    • 127
    What is your preferred method for draining the oil in a really low car? With a m50 swapped lowered e30, I had to custom make a super wide drain pan that could hold 6L of oil and still fit under the car.
    1989 325i m50b25tu swap
    1989 325i (sold)
  • Exodus_2pt0
    • 5943
    Break oil pan on pebble.
    Just refill it after you replace the pan.
    Honestly though, just build step up boards out of some 4x2. Longest piece on the bottom, and work up from there, see below for side profile to get the idea.
    ___________
    ___________________
    Should realistically be able to give yourself 4-6" to get the jack under.
    No E30 Club
    • fresh_TD
      • Aug 2013
      • 2457
      Use and oil extractor like I do for my e46s. You insert the tube where the oil dip stick goes and extract the oil, never have to get under the car = profit!
      Sent from my SAMSUNG-SM-N910A using Tapatalk
      '91 318i (Alpine) - daily
      '88 325ix (Zinno) - drive here and there!
      • Best_name_available
        • Jul 2014
        • 479
        I found some cheap ramps at a thrift store that I drive up on, before that I would do something similar to what exodus said but with just two 2x4s and then use the trunk jack to get it up a little bit, then the floor jack to get it up on jackstands
        Originally posted by Vokuhila
        I laughed, and then I serioused
        • roguetoaster
          Biggus Tippus
          • 7830
          Two sets of low ramps, the higher side depending on orientation of the drain plug.
          • TimeMachinE30
            • Jun 2014
            • 3749
            If that low, and no desire to jack it up.. do the mityvac.
            ACS S3 Build / Dinan 5 E34
            • AndrewBird
              The Mad Scientist
              • 11898
              Stock jack on the side, just high enough to get the floor jack under the front.
              Or drive up on a block like others have said. Depends on how low you are.
              • 5Toes
                • 9836
                I use old fence siding pieces of wood that my neighbor gave me like 3/4" thick by 6 inchs wide
                drive up on a ramp made about 3 or 4 thick to get the jack under the front end.
                if you put some time into making a set of ramps it wouldnt cost much over all and could be customized to fit your car perfect.
                • AwakenNoMore
                  • Dec 2010
                  • 1291
                  This.
                  1991 325i - "Scambles" The Daily Driven lightly modded.
                  1988 Mazda RX-7 TII "Mako" The Free Dorito
                  bacon by Jared Laabs, on Flickr
                  • efficient
                    • Feb 2012
                    • 3312
                    We need pics to see how low you really are?
                    • ST1G
                      • Oct 2012
                      • 6689
                      If you can't figure this out on your own, the struggle is real for you.
                      • Stanley Rockafella
                        • Aug 2011
                        • 4062
                        this
                        and this
                        • rturbo 930
                          • Dec 2005
                          • 2627
                          I just drive up on some 2x4s or 2x6s or whatever's available. Only problem is I always forget to do it the first time.
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            One thing about sucking it out from the top is it doesn't allow you to see the underside of the car to inspect for leaks or other issues. To me, an oil change is more than just replacing the oil with new, I also inspect the rest of the car at the same time.
                            • stonea
                              • 2892
                              This actually made me laugh out loud
                              My Garage
                              Feedback
                              Instagram: Stone.Hopkins
