Ever had parts rusted together?
  • e30onBBSs
    • Dec 2014
    • 1347
    I don't think there is much I can do but have you ever taken something apart and can only go so far? I pulled the driver side front strut and it was smooth sailing. I was ready to take the shock out, anndddddd fused to the strut?! Ever happen to any of you?
    I plan on still going GC coilover conversion until these blow then getting billy's later with "new used" struts
    BMW tech
    Umass Amherst
    05 wrx sti
  • Das Delfin
    • Sep 2014
    • 2293
    Lots of things on my car have fused together. What I did with my struts is leave everything on including the brake rotor when you remove it from the car. Then bolt it back up to the wheel with two of the lug bolts. Set the wheel face down on the ground and sit on it while using a huge pipe wrench to undo to octagon-shaped retaining collar. Douse it with pb blaster and let it sit for as long as you can before trying to undo
    • lukeADE335i
      • Apr 2013
      • 1389
      Nope - haven't had that problem with the e30 - but living in one of the driest places in the world has to have some advantages :)
      My e30: OEM+ with M30B35
      • exhaust
        • Jun 2015
        • 411
        Had this the other day. My steering knuckle was rust welded to the steering column which made my rack swap five times as difficult
        • e30onBBSs
          • Dec 2014
          • 1347
          shit sucks! My friend texted me "the joy of working on old cars"
          #e30
          BMW tech
          Umass Amherst
          05 wrx sti
          • Kershaw
            • 11822
            This was probably 5 years ago, first time I replaced the suspension on my current IX. Strut was so rusted to the shock nut. Large monkey wrench wasn't working, it just rotated and stripped the metal. I used an angle grinder to cut notches into shock/shock collar so it was flat on two opposing sides. I put the monkey wrench into that, fully seated, then used about 6' of pole as a breaker bar on the monkey wrench and another 6 feet of pole through the wheel bearing to help hold it in place on the vise (2 people.) So we had basically 12 feet of breaker bar at use. Straining on that set up for 5 minutes got it to slowly break free.
            Copious use of pb blaster too. That was an absolutely ridiculous experience.
            AWD > RWD
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              You Haven't replaced a rear subframe have you? The aluminum bushing inserts fuse themselves to the chassis 9 times out of 10
              1991 318i 4dr slick top
              Mtech 2 turbo restoration
              • Steven
                • Dec 2012
                • 2305
                This. Replacing subframe bushings was one of the worse jobs I have ever done on my e30 including shaving my bay.
                Feedback!
                Custom Cup Holder Consoles!
                Calypso Story--S50/Shaved and Tucked Bay
                • stonea
                  • 2892
                  I've never come closer to selling my car after I ran into this.
                  My Garage
                  Feedback
                  Instagram: Stone.Hopkins
                  • Click
                    • 637
                    I think I used a 2 or 3 foot pipe wrench plus torch to get my original shocks out.
                    I just replaced the o2 sensor in my e28 yesterday and that was a mother. Even with the big 3/4" breaker bar and torch it wouldn't budge. Ended up cutting the sensor in half and lowering the exhaust enough that I could get the impact wrench on it.
                    Having subframe bushings sitting on the shelf to be installed, I'm looking forward to the job based on all the rave reviews in this thread.
                    ส็็็็็็็็็็็็็็็็็็็็็็็็็
                    I need you to exfoliate my ballsack
                    Build Thread?
                    • TobyB
                      • 5288
                      Even better is where the stud rusts, expands, welds itself to the bushing, THEN the whole mess
                      electrolyzes itself together.
                      I had to drill all the way up BOTH sides of the bushings to get one off. And then replace the stud...
                      On an otherwise clean(ish) car, even by NW standards.
                      t
                      • exhaust
                        • Jun 2015
                        • 411
                        Leaf spring bolts on my Tacoma. Toyotas already rust but add salt belt corrosion and even the oxyacetylene had trouble.
                        • mrsleeve
                          • Mar 2005
                          • 16387
                          short answer
                          YES !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                          I have an old landcruiser and have owned 4 e30s and 15+ other vehicles all from the Midwest or northern states
                          Originally posted by Fusion
                          William Pitt-
                          • estoguy
                            • May 2013
                            • 1087
                            Guess I got lucky, had no problems with this.
                            Worst rusting of parts I've dealt with was the retaining rings on my front struts - I think these were still the original ones, so they'd been in for 30 years. I had to use penetrant and a long Stilson wrench to get them off... this was close to 3 feet long. I put krown rust spray on the new rings when I installed them.
                            Estoguy
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              Land Rover pls.
                              The English didn't believe in captive nuts until like 2001.
                              ......and they fucking rust.
