I didn't even know this was possible to do - snapped shock
  • Kershaw
    • 11822
    After I was nearly done putting my front suspension all back together after correct some minor spring hat to shock mount rubbing, this happened. Nearly the last fucking nut too. You'd think the fucking shock would rotate. I can't have hit for more than 3 seconds either. I was about to stop when it suddenly went all smooth and I knew immediately what had happened.
    I fucking hate my car. Seriously. This IX has given more problems than all other 7 e30s I've had combined. Goddammit. Every time I work on it, 1 step forward, 1 step back. Or 1 step forward, 1 bank account emptied.
    Time to fucking shoot this car. Either that, or order a new bilstein HD shock. I haven't decided yet.
    AWD > RWD
  • ELVA164
    • 4861
    You know, my sister used to have an iX and for every job my 325i has happily accepted and appreciated, that damn thing would always fight me. My professional opinion is the iX is the most hateful breed of E30.
    • Kershaw
      • 11822
      In my amateur experience, your professional opinion is dead fucking accurate.
      And they are even less fun to drive. No powerslides, no burnouts, less shock travel, and they're 150lbs heavier.
      AWD > RWD
      • ak-
        • 12422
        A shop did this to me years ago after I told them not to use the impact and I made them pay for it after some legal threats. They told me to never come back again, lol.
        1991 325iS turbo
        • Kershaw
          • 11822
          An impact is the standard way to put on shock nuts. I can't even recall how many times I've done it over the last 12+ years of working on e30s. Never heard of anyone doing it any differently or having any problems. I googled for a torque spec after it snapped (and I calmed down) and everyone in every thread said, "just use an impact, bro."
          AWD > RWD
          • AndrewBird
            The Mad Scientist
            • 11898
            You used too big of an impact. lol
            3/8" impacts exist for a reason. And technically you are supposed to use a socket with a cutout to fit an allen (or regular) wrench into the end of the strut.
            • Kershaw
              • 11822
              That's exactly it. I've used my 1/2" to install shock nuts and strut mounts dozens of times, but never again. 3/8" for install now only, except lug bolts.
              AWD > RWD
              • Jordan
                • 12916
                While I'm not going to preach to you about not using an impact gun on that nut, which a number of damper boxes tell you right on them to NOT DO.... you've got to have some finesse when doing it.
                If you bury it like a tire monkey attacking a lug bolt it will break. I've seen people break a number of them this way from hitting it too long.
                I use an impact to get the nut seated, then do the final tightening once the weight of the car is holding it.
                https://mtechniqueabs.com/
                • KIRIEIW
                  • Dec 2012
                  • 3385
                  Agreed, everyone I know including myself uses a impact to tighten that nut.
                  1992 e34 Touring- S50 Swap
                  1992 325i-S50 Swap (SOLD)
                  1991
                  • TobyB
                    • 5287
                    ...except on the damned strut nuts, because how the hell else?
                    I have a cheap crappy HF $14.95 version I use for just this sort of thing.
                    It can MAYBE do 50 ft- lbs with 150 psi. If you rattle it for 5 minutes.
                    t
                      • 34844
                      Koni specifically says not to impact them on. I use an electric, but yeah, there's risk of breaking something.
                      • Wille30
                        • Sep 2012
                        • 89
                        Damn that sucks...I get in one of those moods about once a year where I want to sell my ix, but then I fix and start driving it and realize there is no other car I would want.
                        • Kershaw
                          • 11822
                          Anyone want to buy a matched set of Bilstein HDs, only $200, nearly brand new, nothing someone handy with jb weld couldn't fix.
                          AWD > RWD
                          • Kershaw
                            • 11822
                            No takers? Jb weld is totally structural, it'll be fine. :p
                            AWD > RWD
                            • Jordan
                              • 12916
                              Any decent machine shop could repair that and friction weld the threaded section back on.... but the cost of doing so would likely outweigh buying new.
                              Bilstein will not warranty this BTW.
