m62 Short Block - Howz my compresshun?
  • marshallnoise
    • Sep 2013
    • 3148
    I bought this short block for $40 and a 12 pack. I was kind of told that the bottom end should be great. Well, it wasn't. At least I didn't pay a lot for it
    Take a look at this carnage!
    Aaaaand, the money shot, kill shot, whatever you want to call it...
    Basically most of the cylinders show damage, but this one was the proof of a big problem. The groove is deep and wide.
    Just posting this for fun.
    Si vis pacem, para bellum.
    New Hawtness: 1995 540i/6 Claptrap
    Defunct too: Cirrusblau m30 Project
    Defunct (sold): Alta Vista
    79 Bronco SHTF Build
  • flyboyx
    • 8371
    I've seen worse. Is the timing chain and guides good?
    That would surely be worth 40 bucks and a 6 pack
    Gigitty Gigitty!!!!
    • marshallnoise
      • Sep 2013
      • 3148
      The motor was literrally the short block, upper oil pan, e39 engine mount arms, oil filter assembly, cylinder heads with valves (no cams) and 6 head bolts.
      • Kershaw
        • 11822
        Isn't that fixable with a slight hone?
        AWD > RWD
        • marshallnoise
          • Sep 2013
          • 3148
          Alusil can't be honed at all.
          Sent from my XT1575 using Tapatalk
          • Kershaw
            • 11822
            928 Forum - Preparing/Restoring Alusil bores for Dummies - Hi All I have been sure for some time that the process of preparing our blocks for new rings was NOT rocket science or expensive. The forum entry below is long winded BUT well worth reading and is very detailed. Gets interesting from about page 8 onwards....
            Yes you can, but I don't know if your block is too far gone. I can't tell if that's just on the surface or if you can feel it with a fingernail.
            AWD > RWD
            • CoreyZ
              • 384
              I picked up a mint looking m62 from a jy car that looked pretty similar. It might be fine. Alusil is weird.
              • marshallnoise
                • Sep 2013
                • 3148
                I can't crank the engine over without about 100 lb-ft of force on the crank bolt. The one pic on the bottom showing the big score mark? It's deep. Very deep.
                • Kershaw
                  • 11822
                  I guess you have a new coffee table stand.
                  AWD > RWD
                  • djjerme
                    • 5082
                    bore it and sleeve it.
                    You'll spend about what another used block would cost. But then you can go 4-stage NAWWWWSSSS crazy!!!
                    2016 Ford Flex
                    • marshallnoise
                      • Sep 2013
                      • 3148
                      Maybe punch it out to 5.0 if it will allow....
                      • CoreyZ
                        • 384
                        You can grab m62 blocks at pull a part for like $200 though
                        • marshallnoise
                          • Sep 2013
                          • 3148
                          Yep. There is no way I would spend money getting this block back to working order when its so cheap to do something else.
                          • TobyB
                            • 5286
                            Wonder if you'll find a broken ring...
                            t
                            • marshallnoise
                              • Sep 2013
                              • 3148
                              t
                              I'll tear down the rest of the block this weekend and post up pics. I haven't done that to an engine before so I may as well do an autopsy.
