towing an automatic e30....on a dolley, ok?
  • jakeb
    • 1909
    and a pic....
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
    • AndrewBird
      The Mad Scientist
      • 11898
      Originally posted by jakeb
      this is another idea....just wondering
      Could you tow it in neutral with the car running to have the pump running to the trans....
      Just for future reference, this won't work. The pump is inside the tranny and is driven by the rotation of the transmission it self. Having the engine running doesn't do jack.
      I would think though that is neutral towing with the rear wheels on the ground would work. Only the output shaft should be turning that way, right?
      • 88325isboy
        • Mar 2004
        • 1058
        Just call a flat bed man!
        '87 325 (Track Rat)
        '04 C5500 Wrecker (Work)
        '94 525i (Daily)
        '90 325i (R.I.P)
        H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.
          • 34844
          no, the point is towing it in neutral with the rear wheels on the ground will fry the transmission if it's done for long distances or high speeds.
          • jakeb
            • 1909
            yeah towing on the rear wheels with an auto is bad news...
            but towing backwards with the steering wheel locked...is fine.
            Just gotta make sure you don't drive like a moron...everything has to be smooth and slow when towing...expecially with a tow dolley.
            Just glad that everything worked out well today. 3hr drive to where I picked up the car...we were gone from home for 6hrs 40mins. Couldn't have went any better.
            • luvin my 325es
              • Jul 2006
              • 45
              Towing with the motor running and tranny in neutral is fine. If it wasnt you could not put the car in neutral at speed and coast.
              If you tow with the steer axle on the ground always tie the seat belt to the steering wheel, this way you are not relying on the steering lock which can break.
              • ecalder
                • Dec 2009
                • 29
                Haha this is such an old post I'm revisiting...
                Y'all were talking about an automatic here, should I not be worried it I'm trying to tow a 5-speed with the tow dolly with the rear wheels on the ground? Or is it still a better idea to do it backwards like Jakeb did. There's no fluid lines to the engine, but I'd still rather not put any wear on the tranny!
                • Kershaw
                  • 11822
                  if you're towing a 5 speed. put the front wheels on the dolly and the car in neutral.
                  you're good to go.
                  AWD > RWD
                  • ecalder
                    • Dec 2009
                    • 29
                    That's great news! I guess they just assume your car is automatic when you ask if it's OK to tow it. SWEET, THANKS.
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      I towed my car home like that without trouble.
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • ecalder
                        • Dec 2009
                        • 29
                        Yeah I'm just going 60 miles to the track and back...
                          • 34844
                          actually, I remember in the manual it says somewhere don't do a lot of coasting in neutral, either.
                          it's definitely not good for the automatic, and it's not just a BMW thing.
                          • Cabriolet
                            • 9620
                            every single time, which is many, i always call for a flatbed truck. why risk fing anything up?
                            Much wow
                            I hate 4 doors
                            • Brandon12V
                              • 1318
                              I don't understand why anyone would go through this shit when one of these is 60 bucks from U-haul.....
                              Originally posted by Ryan...
                              It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                              • ecalder
                                • Dec 2009
                                • 29
                                I wholeheartedly agree except my x3 towing capacity is 3,500 lbs and the e30 is 2,700 lbs and the tow dolly keeps it under the limit. The full trailer weighs 2,000 lbs alone. I'm going to a DE next weekend that's 60 miles out. I thought it would be nice on the car not to drive it 60 miles, track it, drive it another 60 miles back, and repeat the next day. Maybe I'll rent the flatbed and a truck combo from Uhaul... Thanks.
