Labor Cost of Replacing Heater Blower Motor and Resistor
  • fakeplstctrees
    • Jun 2013
    • 92
    Hey fellow E30 lovers, I brought my cabriolet into the mechanic with the parts. I only needed them installed. What's a fair price for the labor to install the blower motor and resistor?
    Thanks everybody!
    Sent from my SM-G930P using Tapatalk
  • e30sh
    • Apr 2015
    • 618
    Some shops have an hour minimum charge. If they have worked on an e30 before, shouldn't take more than 30 min.
    • Matt-B
      The Waffler
      • 3856
      dont be surprised when they quote you 1000$
      its a major pita depending on motor
      • e30davie
        • Apr 2016
        • 1788
        From the opening post i get the impression he has already dropped it off at the mechanic.
        Hopefully the mechanic doesn't see it as an open chequebook.
        • e30sh
          • Apr 2015
          • 618
          4 bolts for the access cover in the engine bay and a spring clip holds the blower motor in the housing.
          It's not like a lot of cars where you have to remove half the dash.
          • Matt-B
            The Waffler
            • 3856
            if only it was that easy lol, the m42, and m50s etc, you may as well remove intake
            • e30sh
              • Apr 2015
              • 618
              He said it was an e30 vert so I assumed an i motor. No mention of an engine swap. If it's an M42, there is an engine harness clipped to the access cover but that's no big deal.
              • Matt-B
                The Waffler
                • 3856
                you must install a lot of blower motors and its been a breeze every time
                • e30sh
                  • Apr 2015
                  • 618
                  Not that many but never had one fight me so maybe I'm lucky. A couple of the access cover screws can be a bit of a pain to get to but overall a pretty easy job.
                  There are DIY videos on youtube for those that want to try it themselves.
                  • JasonC
                    Site Manager
                    • 14451
                    I just changed the resistor and blower motor on my vert. Not hard at all. Don't know why people bitch about it. My only problem was the clip didn't want to snap back in once all together.
                    1992 BMW 325iC
                    1978 Chevrolet Monte Carlo
                    • McGyver
                      • 4636
                      I would expect you to be charged at least an hour, probably 2 hours, at your local labor rate. For an e30 with an m20, it should only take them 45 min to complete the job.
                      As a side note, I would never install customer provided parts. After having been a mechanic, I would also be very nervous taking my car to a shop that allows me to supply parts.
                      • cory58
                        • 1021
                        Every reputable independent BMW shop I've used would let me supply parts. My parts are always OE, OEM, or OEM equivalent. Not sure if that makes a difference, or how they would respond if I showed up with parts from AutoZone.
                        Cory
                        1992 325i Cabrio
                        1988 320i Touring
                        2000 M5
                        1977 530i
                        2015 328i - Euro Delivery/Performance Center Delivery
                        BMWCCA
                        E30CCA
                        • McGyver
                          • 4636
                          Cory
                          Say you think your starter is bad:
                          Did the shop diagnose the starter as the problem, or did you bring them a part and ask them to put it on the car? What happens you just asked them to put the part on and it didn't fix anything? What happens if your OE starter fails after a month? Obviously your warranty covers the part, but who covers the labor of putting in another starter? Do you have to buy a second starter so the shop can just remove and replace, or does your car take up space on their lot/lift while you wait for a new starter?
                          When a mechanic diagnoses an issue, supplies the part, and installs the part, all the responsibility is on the shop. As a shop, I wouldn't want to warranty any customer supplied part or the labor to install it. Also as a shop, I wouldn't want to lose profit to an online retailer.
                          So personally, I would be nervous about a shop that gives up profit and assuming the labor cost if a part fails.
                          • Mook613
                            • Apr 2016
                            • 232
                            The shop I use will let me supply a part based on an agreed and thought out diagnosis. BUT, they clearly say every time that they will not warranty any of it.
                            Can't confirm, but suspect that they only do this for very select customers that they know have extensive knowledge and ability. The only thing I ever really go to them for is for things that either require tools that I do not have or for work that I'd rather pay somebody else to do.
                            • djjerme
                              • 5082
                              As long as you are OK with that, and it's all in writing, most shops would be fairly fine with that. Obviously, many of us have different relationships with shops being enthusiast. But Jane waffleswaffleswaffles with her BMW mini that blew up a motor (again) probably isn't going to be showing up with a good pull she sourced from somewhere and expecting a full shop warranty.
                              2016 Ford Flex
