Question on 1986 325
  • Lizard 1
    • Jun 2018
    • 54
    So, have a local guy with an E30 for sale. It’s a 1986 325. No “e”, “Es”, “i”, etc.
    He claims it is an “i” model but do any show on the trunk, is cloth interior. Is this not an eta motor even though not showing an “e” on the trunk? Trying to figure a value of a 78k one owner 5spd.
  • James Crivellone
    Head Janitor
    • 6305
    BMW Made base models in 86 - 88, all of which were ETA engines (except for 88 with the SuperETA)
    Unless it was swapped, you have a basic M20B27 in there. The Intake Manifold, Coldstart Valve, and 5K Tach will also give it away.
    • Lizard 1
      • Jun 2018
      • 54
      Am I correct in thinking the standards were just badged 325?
      • James Crivellone
        Head Janitor
        • 6305
        Standard as in Stick?
        My 86 325 (no letter) had a ZF Auto in it.
        • Lizard 1
          • Jun 2018
          • 54
          Sorry. Standard as in base model.
          The redline starts at 4500. He is still saying it is an “i”.
          • reelizmpro
            • 9559
            Yes it's a base model. The fact it's an 86 means it must be an ETA since the 325i didn't come out until 87.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • Javier h
              • Sep 2007
              • 1189
              This isn't some euro car, right?
              Wiki show "i"s starting in 1985. I have a seen a few 1986 convertibles for sale. I always assumed they came with "i" engines but could have well been typos in the ad.
              Regardless, this is an eta cluster:
              This is an "I" cluster:
              I am pretty sure that's just a regular eta especially if the seller says its a U.S. production car with no engine swap.
              Sounds like a nice car being sold by an uniformed seller.
              Javier
              • McGyver
                • 4636
                OP, thats a euro early eta cluster and a US late i cluster.
                Javier's point is that the eta cluster rev's to 4.5k and the i cluster revs to 6.2k
                If it's a US stock 1986 325, it is an eta. So unless the seller did a bunch of stuff to it, it's an eta.
                • Javier h
                  • Sep 2007
                  • 1189
                  OP, I switched the correct eta US production cluster in my image.
                  Javier
                  • McGyver
                    • 4636
                    Javier
                    Still 1 VDO and 1 MotoMeter
                    • wolfador
                      • Mar 2018
                      • 33
                      My 86' eta is badged "325".
                      86 325e sedan
                      • Magnaflow Cat-back
                      • SSSquid Stage 1 Chip
                      • e30davie
                        • Apr 2016
                        • 1788
                        Remember the cars are 30+ yrs old. Could have a tractor engine in for all you know.
                        • ttrousdell
                          • Nov 2009
                          • 1770
                          Some lowlife trying to pass off his eta as an "i" to some ignorant buyer. I see it all the time on craigslist.
                          The Build:
                          • 325e '87
                            • May 2017
                            • 503
                            Snap a pic of the vin number, then you’ll know that it’s an eta and you can prove it to the seller.
                            If it’s truly a 1 owner car then the guy telling you it’s an i is being dishonest, or he’s not the owner.
                            If the car is in good shape it’s worth a decent amount. There are garage kept lightly driven cars out there.
                            My son has the 1987 325e, 2 door, 5speed
                            I daily the 1989 325i, 4 door, 5speed
                            • E30 Fitment
                              • Dec 2016
                              • 35
                              If it red lines at 4500 it's definitely an eta. My car is a 1987 325 too and it also has eta motor even though it doesn't have the "e" on the back. I believe you can also check if it's an eta by looking in the door jam. I could be wrong, but I believe the door jam sticker should say the engine model or information. Also I don't know if all cars had this, but my car also had a sticker in the engine bay saying it had eta engine model which came in 325, 325e, and 325es. Additionally if the car has the original motor and is a true 1986 car then it has eta motor (unless it's a vert). All 1986 and earlier models came with the eta engine except for convertibles; only some 1987 models came with i engine, but it's pretty uncommon.
                              I could be wrong on some of this information, but I'm pretty sure it's all factual. You might want to check the VIN just in case too, he could have swapped an 'I' motor into it.
