spark plug replacement question
  • german g
    • Feb 2006
    • 1608
    How do you remove the small black plug (the wire that is not to the coil or to a spark plug) on the drivers side of the engine. I switched my plug wires and cant seem to figure out how to get this little plug off..It seems like it just snaps on/off...I have to be doing something wrong.
    90is, longtube headers/straight pipe/mark d 18# 93 0ctane chip/18# injectors/vogtland springs/bilst. sports
    :firehop:
  • Mike325
    • Mar 2006
    • 3685
    Not sure what you mean. Is it a spark plug wire? I don't think any wires for the spark plugs go onto the driver's side. I will post up a pic and maybe you can point it out.
    Originally posted by Kershaw
    • Mike325
      • Mar 2006
      • 3685
      I'm assumeing you have the m20b25?
      • german g
        • Feb 2006
        • 1608
        thanks man, yea, its a m20b25..
        It is a wire that plugs in underthe round thing..I circled it in red.
        here is the little bugger...
        :firehop:
        • bmws50b30
          • Aug 2005
          • 1151
          if you are not planning on selling your used wire i would just unplug it and cut it off. you'll just have to route the new one the same way and make sure it doesn't get caught on any moving parts. take note of how the old one is routed.
          1991 330is
          • german g
            • Feb 2006
            • 1608
            I cant unplug the little black thing that I circled though..
            :firehop:
            • Mike325
              • Mar 2006
              • 3685
              I would try to help but my eta does not have that.
              • german g
                • Feb 2006
                • 1608
                damn, someones gotta know how to get this bastard off!!
                :firehop:
                • moatilliatta
                  • 6158
                  you mang give me a holla if you need some help. im free i think all week. Getting fired ftw!"
                  @Zakspeed_US
                  • german g
                    • Feb 2006
                    • 1608
                    I might give ya a call tonite, Do you know what that plug is and how to get the bastard off??
                    getting fired, that sux bro. You should take up engine bay detailing as a carreer :-)
                    :firehop:
                    • moatilliatta
                      • 6158
                      yeah. haha. i belive so. i had a problem also. it will pop off though. you just have to be careful. alright later on.
                      @Zakspeed_US
                      • bmwguru007
                        • 561
                        I'm pretty sure it has one of those spring type clips that you have to push in. Similar to the coolant temp connectors.
                        • bmws50b30
                          • Aug 2005
                          • 1151
                          check your new wires on how it will attach. remove the old one the same way. i can't remember how i removed mine because i don't have an m20 anymore but i also had a hard time removing that wire when i replaced my wires. hope this helps and good luck
                          1991 330is
                          • dlmpsy
                            • Sep 2006
                            • 189
                            If I'm not mistaken, that wire has to do with the impulse sensor. It is retained by a metal clip. Someone may have put the clip on from the bottom, which would make it difficult to see. Use a small screwdriver and lightly pry on the metal clip...be prepared for it to fly-off. However, you will want to reuse it and install it from the top.
                            • AdironRider
                              • Dec 2004
                              • 3491
                              I dont ever remember having trouble removing this piece. I was also in the middle of a timing belt swap but even then I think it wasnt even an issue.
                              Back to my roots
