Krylon Wrinkle Finish Paint
  • deansbimmer
    • 674
    Do you think that this paint will be OK for the intake and/or valve cover? If it is not, will it just bubble and flake off?
  • Keith M
    • 2338
    I should work fine. Just make sure you follow the directions and clean the area throughly with wax and grease remover, (not bug and tar) or lacquer thinner. After you paint the valve cover, sand the raised area, using a hard block so you don't mar up your fresh paint.
    Keith
    • E30 Reaktionär
      Site Manager
      • 14451
      i used that paint on my intake and valve cover. It's starting to flake, but i don't think that i got it that clean. Plus i used it on other things and it stuck really well. Here is a pic. of mine, you can see where it flaked but it stopped and has not flaked off any more.
      1992 BMW 325iC
      1978 Chevrolet Monte Carlo
        • 34839
        I used it on mine, but I cleaned it very carefully. has held up fine for the last 4 years.
        • loonibab325i
          • Dec 2005
          • 770
          http://www.strictlyea.com/features/valvecover.html
          I used VHT wrinkle spray paint there should be some pics in that link, it's still doing good and it's been 5 months so far..
          s52 0-150mph & more http://www.youtube.com/loonibab325i
          • O 16581 72452 5
            • 1066
            I used it and it flaked bad, i suggest high-temp, won't wrinkle, but it'll last..
            • StereoInstaller1
              GAS
              • 22679
              Do not waste your time and effort. Go to your nearest Harley Davidson store. Buy official HD wrinkle paint. There is nothing like it anywhere. It is absolutely fucking amazing.
              FOLLOW THE DIRECTIONS!
              They are not kidding about not using an oven that will be used as a place to cook food ever again. The smell never goes away. Never.
              You will find that with minimal effort you can do a wrinkle finish that will be damn near indestructable. Attack that stuff with a screwdriver and it is still hard to scratch. The wrinkle is tight and beautiful, just like an HD engine.
              Expect about $22 a bigger-than-average can.
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • george graves
                • 19996
                Luke
                Guess I'm going to have to succum to visiting a HD store to see "thigh and beautiful" finish(no clue what it looks like)...Hmmm...Sounds like a cool product!!!
                Originally posted by Matt-B
                • StereoInstaller1
                  GAS
                  • 22679
                  "thigh and beautiful" sounds like a fat chick and a hottie to me!
                  Closing SOON!
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    If you don't have an oven to destroy, go get a big cardboard box and a space heater. Put the parts and the heater inside and let it sit for a while. Won't be AS great as an oven, but it will be better then leaving it in the sun.
                    And don't worry about the box burning, paper doesn't ignite or burn until it reaches 451º degrees. Most small space heaters won't get it NEARLY that hot inside.
                    • blueapplesoda
                      • Dec 2005
                      • 1904
                      i solved that oven problem...
                      i lined a carboard box with foil, then cut a hole out on top of the box to fit just the front of my dual 500 watt work lamps....i left it for a good 10 minutes and the valve cover started smoking due to the oil inside and on the underside. of course doing it outside in the open. and be weary of fire...the box gets pretty hot so keep an extinguisher nearby if it does...but mine came out real clean. the wrinkles were rock hard and it feel/looks pretty tough. Yesss rock hard.
                      i feel a flame coming on for my ghetto oven idea...should i get my nomex suit ready?
                      • blueapplesoda
                        • Dec 2005
                        • 1904
                        u beat me to it mang
                        oh and btw i used harley paint
                        • e30frosh
                          • Dec 2004
                          • 2170
                          Originally posted by NitroRustlerDriver
                          451º
                          Farenheit 451, great book.
                          I know this is OT, but my gf is getting me a copy of Salinger's "Catcher in the Rye" from a guy named Mcvey. Just thought that was odd....continue
                          Every day I wake up we drink a lot of coffee and watch the CNN
                          Every day I wake up to a bowl of clover honey and let the locusts fly in.
                          Lobsterbacks attack the town again
                          Wrap all my things in aluminum
                          Beams of darkness streak across the sky
                          Pink rays from the ancient satellite
                          Every time I look out my window same three dogs looking back at me.
                          Every time I open my windows cranes fly in to terrorize me.
                          • e30s52
                            • Oct 2007
                            • 5235
                            im going to try this on my s52 cover and intake.
                            www.gutenparts.com
                            • uofom3
                              • Jan 2004
                              • 5392
                              Luke
                              QFT - do this and you'll be happy.
                              I would also strip the thing with aircraft aluminum stripper - that shit works amazingly well.
                              PNW Crew
                              90 m3
                              06 m5
