HID in US ellips...Update: part 2!!
  • golde30
    • 11464
    well, when i got my 88 325is, i was happy to finally have some ellips, but the lighting is HORRID! i mean, i can barely see the beam pattern on the street. so after about 2 weeks of driving this car, i remembered that i have set of HID lights offa E320...now i know what u all are thinkin, why the hell havent you used these before...well my reason is that the wiring on these things is rediculous...i mean most HID systems have like the balast, anda wire to the bulb....well, these have a balast, with about literally, 20 wires coming out of it, going to about 5 different plugs...so i never tried to figure it out, but 2day i got curious,and decided to sit down and untangle the mess of wires and figure this thing out....
    well, after much testing with a volt meter and a car battery, i found the power and ground lines, and dremeled out the base of the HID bulb to fit into a 9006 housing, and viola, i now have a kick ass freakin HID system in my e30!!! let me tell you guys, all i have to say is DAMN, why didnt i do this before, the lighting is FAR superior to any other bulb, and with the ellips, theres no need for a leveler, the beam is perfect, i only have one side hooked up as of now b.c of time issues, but that one beam lights better than my 2 lows, and 2 highs put together... i will take a pic of the difference 2m with my frens digi cam, its crazy...
    IG: @Baye30
  • golde30
    • 11464
    here we go...
    IG: @Baye30
    • Rob
      • 8166
      bright!
      BEERTECH
      • Jordan
        • 12916
        what did you take those with? a webcam?
        https://mtechniqueabs.com/
        • SlammedE30
          • 741
          I am looking forward to putting HID's in my US ellips :) Thanks for the pics :up:
          -Ted
          • bimmerphile
            • 3495
            Group buy, baby. Group buy 8)
            • golde30
              • 11464
              actually it was a 3.2megapixel camera...but it doesnt take good pictures at nite...and with the flash u cant see the lighting effect as well...
              IG: @Baye30
              • theberglar
                • 143
                Turn the flash off and use a tripod or surface to steady the camera. You'll get much better pictures, like these:
                • golde30
                  • 11464
                  hmm...well, kinda needs a tripod, and a cam with adjustable shutter speed. the pics are also kinda huge, my frend isnt very camera savvy... :roll:
                  but every1 gets the point rite? :D
                  IG: @Baye30
                  • E30ownerwithanopinion
                    • 1526
                    what set up are you using?
                    I had HIDs in the cabrio like 2 years ago Skidmark aka Andre wanted them so bad he brought them right off my car LOL at about 2x what I paid but what ever....
                    I had Hella ballasts and phillips bulbs....
                    • BavarianBimmer
                      • 951
                      Welcome to the HID bright light brigade :up:
                      1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
                      1997 E36 328iT
                      1990 E30 325iT 24v SOLD
                      1989 E30 325i 2.7i M-Technic II SOLD
                      • David325is
                        • 194
                        What temperature rating are those bulbs?
                        • jweb
                          • 959
                          I have a question. I just got my bulbs and ballasts today, so I plugged a ballast in, and put the bulb in the ballast socket. I then turned the car on and turned the headlights on. The bulb turned on and stayed on for maybe 2 seconds, then turned off. Now it won't turn on again and my regular halogen bulb won't work. Did I blow a fuse or something?
                          Jamie Webster
                          '89 325is - sold :(
                          '96 Miata - sold
                          '01 M5 - sold
                          '02 Civic Si
                          • jweb
                            • 959
                            Turns out I did blow the #14 fuse, I just replaced it and the halogen bulb works fine, but why did the HID ballast and bulb blow my fuse?
                            Jamie Webster
                            '89 325is - sold :(
                            '96 Miata - sold
                            '01 M5 - sold
                            '02 Civic Si
                            • BavarianBimmer
                              • 951
                              It needs more amps by startup cold ;)
                              1997 E36 328iT
