Injectors are definately not the issue as i am running around 230hp at flywheel on stock injectors with no fuel problems.
The head on the M20 yields little power as the stock unit was a very good design.
I only got 6hp gain after spending £2400 on the head ($4100.00) and that was without the cam which gave a further 4hp in true terms.
I would check your fueling system is running right and also take a good look at your air flow meter and your electrical side to see if your leads or plugs are not breaking down somewhere.
I have a chip for your car that will run it perfectly.
