KW 60/40 suspension. back seems high? hope it settles?
  • hammoj28
    • Mar 2004
    • 92
    I don't post on here much but as a lot of you guys seem to use KW suspension i thought id better as you prob know a bit bout it.
    I fitted my KW 60/40 kit on my 318iS. The front has dropped really nicely but the back seems same as standard? I have taken it for a 25mile run(handles brilliantly now).
    Some people have said it will take around 200-250 miles normal driving to settle.
    is this right? Will it settle?
    I hope so. Rather worried.lol
    any help much appreciated.
    Cheers.
    James.
    thelowcartel: https://www.facebook.com/thelowcartel
  • z50_Jumper
    • Apr 2007
    • 1520
    I like the stance, but yes, going to take a lot more than 25 miles to settle. I would say atleast a couple hundred to see any difference, within 500 miles it should be at its resting place.
      • 34835
      you also might have the thicker rear spring pads - there are 2-3 different sizes available. if it doesn't settle enough, you can replace them with thinner pads.
      • hammoj28
        • Mar 2004
        • 92
        Ahhh, thats a relief. Does it normally look high with these kits? Cant wait for 500 miles time!lol
        Oooh, nice one. I never knew about the thicker rear spring pads! Are they the rubber things they rest on? or something else? if it don't settle i will do that.
        Thanks very much for the replies.
        • ebelements
          PBMW Feature Car
          • Oct 2005
          • 403
          That looks about right to me. It doesn't take that long for a car to settle, so if you've driven it for a day, that's how it's gonna be.
          In my mind, that is how E30's should have come stock. Clean, safe, daily ride height. Looks good!
          Erik
          • hammoj28
            • Mar 2004
            • 92
            Cheers, kinda hoping it will settle. I think it is. But im going to wait a while.lol.
            • gearheadE30
              • Jun 2007
              • 3734
              dang, that's one sharp 318. I'd check into the spring pads, because I've never seen coils settle after 50-100 miles of installation... Either way, I like the foreward rake.
              Project M42 Turbo
              • hammoj28
                • Mar 2004
                • 92
                Cheers, it came like that from factory.
                It has settled a bit i think tbh. Will take a pic tommorrow.
                Think i will get the 5mm spring pad tho aswel.
                Starting to like the rake myself a bit. Handles really well now too.
                • Mastrcruse
                  • Sep 2005
                  • 5340
                  It was suggested me, by someone that had 60/40 drop, to just go with the 60/60. It looks great on the coupe but on a vert it looks like oil pan suicide.
                  That looks good though
                  • Jon325i
                    • 6934
                    Just keep a full keg in the trunk. That or a body :-P
                    Jon
                    Rides...
                    1991 325i - sold :(
                    2004 2WD Frontier King Cab
                    RIP #17 Jules Bianchi
                    • rThor432
                      • Feb 2007
                      • 3907
                      Jon
                      I prefer about 30 nitrous bottles and 12 subwoofers, but that is just preference. Kegs work too.
                      • erik325i
                        • Jan 2005
                        • 3567
                        Just remove the spring pads completely. You do not need them.
                        -Erik
                        • egk2
                          • 2426
                          Looks about right. It won't be drastically lower
                          when they settle. 60/40 kits are supposed to sit
                          that way, forward rake. I had the same springs
                          installed on my e30 and always wished they were 10mm '
                          lower in the rear to be spot on.
                          • hammoj28
                            • Mar 2004
                            • 92
                            Erik, are you sure you don't need the spring pads?
                            Yeah, it has settled quite a bit i think, looks better than that photo anyway.
                            • gearheadE30
                              • Jun 2007
                              • 3734
                              Spring pads are only there to reduce noise and fiddle with ride height. Because the springs are compressed between what is essentially 2 arms, the bases slide back and forth. Push down on the back of the car and you will hear a creaking noise.
                              Project M42 Turbo
