Cup Kit for Convertible
  • Jordan
    • 12913
    Originally posted by ///M Powered
    would a 318i be too high for the h&r cup kit? i was about to get it......
    318i is lighter then a 325i. It wouldn't lower it quite as much. Also, the cupkit wont fit a 318i as a 318i has smaller diameter strut tubes, and it will not fit struts designed for a 325i on it.
    https://mtechniqueabs.com/
    • ///M Powered
      • Jan 2004
      • 1109
      good looking out :up:
      • rwh11385
        lance_entities
        • 18403
        you can do a search and probably find Rob's 318is when he put the Cup kit on it.
        • ///M Powered
          • Jan 2004
          • 1109
          i thought the 318is and the 318i were diff as well :?:
          • rwh11385
            lance_entities
            • 18403
            they are, but the amount of lowering is probably close, just to get an idea.
            If you use any 325-specific spring rates it will ride (most likely) higher with a 4-cylinder.
            • Pedro
              • 965
              What is the best suspension set up for the M42?
              http://www.volkswagenjettacup.com/
              • graphik
                • 361
                Cup Kits already sit too low in the rear, It will look like your car is bent over taking a dump.
                Only if you have the gay later lower arches ;)
                It looks pimp on early arches.
                all cabrios have the later arches
                • Digitalwave
                  is a poseur
                  • 6293
                  You seem to forget that 318i's have 45mm front strut tubes, and the Cup Kit will not work on them.
                  RISING EDGE
                  • randomtask37
                    • 3154
                    does that include sayyy a 91 318is?
                    98 M3/4/5
                    • Digitalwave
                      is a poseur
                      • 6293
                      No, that's why I said 318i's.
                      RISING EDGE
                      • Rob
                        • 8166
                        describe best. Lowest? Cheapest? Best handling On track? On the street? off road?
                        best is very vague
                        BEERTECH
                        • rwh11385
                          lance_entities
                          • 18403
                          they are
                          I didn't say it work, I agreed they won't. I said he should look at Rob's car to see how springs drop the lighter car differently. ;) As in other springs....but comparing Cup kit on 318is versus everyone else who has the cup kit gives a good impression of the difference.
                          I said this before, but then deleted it. Answer: Ground Control. ;)
                          GC: Could be, if you want. NOPE. Highly probable. " "
