frozen key tumbler
  • 0000000000
    • 473
    frozen key tumbler
    OK heres the deal it started raining than its starts getting really cold.
    I go outside after work to try to unlock my door and its frozen shut.
    i go to the gas station to get a deicer and used it and its still frozen shut.
    the key turns to the right fine, but to unlock its turning a lilttle bit but doesnt unlock my door, than i tried my hardest to turn the key to unlock it starts to move but the lock is still locked. so than i tried to move it back to the normal postion but it doesnt go all the way back to normal position.
    some one please help?!
  • BDSax
    Junkyard King
    • Mar 2006
    • 3594
    get WD-40 with the red nozzle. inset the nozzle and spray a bunch in there. nasty black crap will flow out and keep doing it till its smooth
    • 0000000000
      • 473
      already tried that, its freezing cold out.
      • Maluco
        • Oct 2005
        • 6572
        unlock doors via trunk FTW...
        • 0000000000
          • 473
          i dont have central lock.
          is there a way i can get in my car from the truck
          • JasonC
            Site Manager
            • 14451
            1992 BMW 325iC
            1978 Chevrolet Monte Carlo
            • thectrlguy
              • Apr 2007
              • 1042
              A couple cups of hot water, plus lock deicer. Poor water on face of lock, and on lower portion of window (directly above lock, some should leak into door area, and onto the lock mechanism itself).
              Flush lock with deicer and/or WD-40.
              Or just piss on it, until it opens....
              • atomic
                • Jun 2007
                • 5691
                KAFKO - PEEL'n STICK LOCK DE-ICER & LUBRICANT can be purchased at your local Lowes hardware store in the key department
                • 0000000000
                  • 473
                  you cant poor hot water on it.
                  • WillisE30
                    • Jan 2007
                    • 831
                    The locks in the e30 are really shitty for cold weather. You may have damaged it by forcing the key, be aware of that. Short of heating the lock up there's not much you can do. Once you're in try pulling your door panel and cleaning and lubricating the lock mechanism.
                    Mine barely work at all anymore, I need to get some new ones!
                    sigpicFormer professional wrench thrower.
                    Current:
                    1988 325is S52
                    Former:
                    2008 Sparkling Graphite M3 Sedan(victim of home ownership)
                    1988 M5
                    1996 328is
                    • 0000000000
                      • 473
                      what if i already damaged it a little bit?
                      • thectrlguy
                        • Apr 2007
                        • 1042
                        You're joking right?
                        • 0000000000
                          • 473
                          if hot water gets in the locks it will freeze it, i know its hard to take in but here
                          http://www.ehow.com/how_2067178_open-frozen-lock.html
                          • Maluco
                            • Oct 2005
                            • 6572
                            you could just part the car...
                            • 0000000000
                              • 473
                              lol, your funny. I just got that car about a month ago.
