frozen key tumbler
  • atomic
    • Jun 2007
    • 5691
    there is always this too ...
    • Tarn
      • Sep 2006
      • 212
      Use a heat gun. Or get central locking on the car with a remote :D
      • thectrlguy
        • Apr 2007
        • 1042
        1. Cup of hot water
        2. Pour water onto lock mechanism
        3. FLUSH LOCK WITH DEICER AND/OR WD-40
        This will thaw the lock, and remove any water... what do you think happens when you wash your car?
        I know it's hard to take in, you flipping half-wit..... maybe you should write a ehow article after you're done here.
        Originally posted by 0000000000
        if hot water gets in the locks it will freeze it, i know its hard to take in but here
        http://www.ehow.com/how_2067178_open-frozen-lock.html
        • crunk3
          M5
          • Sep 2006
          • 1182
          Passenger door?
          91 318iS http://www.cardomain.com/ride/2396154
          • Kruzen
            • Mar 2004
            • 5603
            I've never had my locks freeze from usage with the trunk mounted central locking mod. I can't twist my lock with the key in this weather to save my life but the trunk always unlocks it for some reason.
            Who doesn't love a little BBQ?
            Griot's Garage at a Deep Discount
              • 34844
              keyless entry FTW
              my locks were always perfect though until some fucking homeless prick tried to use a screwdriver to break the lock.. didn't work but now it's a bit sticky. good thing i use keyless most of the time..
              • AndrewBird
                The Mad Scientist
                • 11898
                DO NOT USE WD-40 ON LOCKS. All it will do is collect dirt and clog the lock. Use graphite based lock lubricant instead. It's made to wick away water and will not hold dirt like oil will.
                This stuff is the bomb:
                http://www.amazon.com/LOCK-EASE-GRAP.../dp/B000CIJUGA
                As far as deicing, I've used a pencil torch before with great success. Heated just the lock cylinder and nothing else.
                • 0000000000
                  • 473
                  my locks are pretty fucked now.
                  I think i broke them, so im gonna break my window, i have a friend that as a extra rear window. so im just gonna use that.
                  • Maluco
                    • Oct 2005
                    • 6572
                    Post pics or a video of you breaking the window!!!!
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Being as this is an e30 board, Id assume with that type of reply you must have a thing for snuff films.
                      • 0000000000
                        • 473
                        I already did, sorry.
                        I taped up the window with duck tape and left some off so i could break the window.
                        I took a pieace of porselen used my pliers to hold it and hit it against the window, one try adn phress window busted. The other is held on with the tape reached my hand in there and tried to unlock it and had a hard time unlocking, so used my pliers to pull up on the lock and all i heard was cresshshs from the ice crushing.
                        Good thing i have a friend that has a extra rear passenger window.
                        • e30 Luv
                          • Dec 2006
                          • 395
                          thats pretty extreme, i think you got a little carried away on this one. My locks freeze all the time and i have never considered breaking the window to get inside.
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            His meth pipe was in the rear ashtray. What would you have done?
                            • 0000000000
                              • 473
                              my locks are fucked, it just keeps turning and doesnt unlock on both sides.
                              • BBY1104
                                When mine are cold and it is frozen (keep in mind this is not sanitary) I put the key in my mouth for like a minute and stick it in the lock and work it back and forth. Has always worked for me. Sorry you had to bust the window
