Parts Cleaner?
  • rs4pro3
    • 5808
    Ya I used latex gloves once and it sucked, from then on no gloves at all. I've got small hands so gloves almost get in the way as they don't fit well.
    85 325e 2.7 ITB'd stroker
    • AndrewBird
      The Mad Scientist
      • 11898
      Originally posted by Jordan
      Originally posted by M-technik-3
      Gasoline? Jordan wow wheres the EPA? It's too rough on your hands and gloves don't stand up well to it either.
      Screw the EPA. I have man hands, and never use gloves.
      Damn right. A number of times I have dipped my hand into a bucket of coolant/oil/tranny fluid to get a dropped part and not even thought twice about it with my watch on and everything. Not to mention sat my head in a puddle or two of the above mixture by accident while crawling around under a car. If you are scared to get a little dirty, then you shouldn't even be near the underside of a car.
      Andrew
      • RedBaron86325
        • 386
        I like Simple Green, Brake Parts Cleaner, and the Castrol Purple stuff, but nothing cleans like gasoline. Use a screwdriver to scrape off some of the caked on shit, then use gasoline and a brush...the grime will come right off.
        Don't forget the good things Hitler did.
        • rs4pro3
          • 5808
          What about Paint thinner? I'd rather use that then gasoline.
          • Nate325ic
            • 462
            just soak it in something for a bit, it can be simple green, paint thinner, gasoline what ever the hell you like than run it to your local car wash, throw in the buck fifty or so in quarters and use the preasure washer to get the crud off. for small parts get a shitty crock pot that you dont use anymore and fill it with coolant heat it up and let parts soak for a few hours, I used to do this with my little glow plug engines when I flew r/c airplanes
            • george graves
              • 19996
              Wow - that works? Coolant? Really?
              Originally posted by Matt-B
              • Nate325ic
                • 462
                is that sarcasm I detect?
                • 808BMW
                  • 2910
                  Gas and pure superclean, thats what I used when my motor was in pieces.
                  Man hands take it like nothing, just watch out if you have a cut (man hands shouldn't have cuts either)
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    No, man hands will have cuts from working on cars. Men will not flinch when gas gets in those cuts. :twisted:
                    Andrew
                    • kencopperwheat
                      King of Kegstands
                      • 14396
                      If you're going to be using gasoline wear some thick gloves. Hydrocarbons, especially any cyclic-unsaturated ones are not nice to your body (read: carcinogens).
                      Originally posted by Gruelius
                      • RedBaron86325
                        • 386
                        Nearly everything is a carcinogen. A little gasoline on the hands is probably less dangerous than smoking a bowl.
                        • Digitalwave
                          is a poseur
                          • 6287
                          RISING EDGE
                          • george graves
                            • 19996
                            no - that's really is a new one for me...learn something everyday here!
                            • bimmerlover
                              • 424
                              You guys are such wusses! Even I clean parts in gasoline without gloves. I don't see what the big deal is.. toughen up! ;)
                              • Rob
                                • 8166
                                i have to touch my girlfriend with my hands so I wear gloves :P
                                BEERTECH
