89 M3 springs on my Convertible?
  • parkerbink
    • Jun 2004
    • 10138
    Good idea? bad idea? Won't fit?
    Do I have to get a spring compressor to remove/replace the fronts?
    I can get them cheap opinions please?
    Thanks!
  • mph
    • Jan 2004
    • 536
    Re: 89 M3 springs on my Convertible?
    Thanks!
    My cabrio has m3 springs on it. I couldn't tell you too much as to how the ride has changed because they came on the car.
    Current BMW's:
    2004 330Ci
    1986 European 325i cabrio
    1986 735i
    Previous BMW's:
    1989 325is RIP
    1989 325iX RIP
    2001 740iL RIP
    • parkerbink
      • Jun 2004
      • 10138
      Thanks That tells me they fit! he he Guess i'll get them.
      • kencopperwheat
        King of Kegstands
        • 14396
        It'll lower it about 1/2 - 3/4" all around. And they're much stiffer than OEM springs.
        Originally posted by Gruelius
        • parkerbink
          • Jun 2004
          • 10138
          Cool ! What about the spring compressor? do I need one or does it just nicey come apart? Some are really under pressure, some not. I need to be prepared!
          • James Crivellone
            Head Janitor
            • 6304
            You need a spring compressor for the front, rear you don't really
            • parkerbink
              • Jun 2004
              • 10138
              Great Thanks!!!
              • mph
                • Jan 2004
                • 536
                My car is pretty hard on bumps.
                Current BMW's:
                2004 330Ci
                1986 735i
                Previous BMW's:
                1989 325is RIP
                1989 325iX RIP
                2001 740iL RIP
                • parkerbink
                  • Jun 2004
                  • 10138
                  mph what shocks do you have? for now it will be stock shocks (unless I come up with money from heaven)
                  I ordered the spring compressors.
                  • mgold
                    • 709
                    I'm running E30 M3 springs and KYB shocks on my car. It dropped it about 3/4" all around and gave it a slightly stiffer ride, but not harsh at all. You should get a slightly lower drop given the significant weight difference between the 318ic and the 325ic. The rear springs can be a bitch to get out but the M3 rear springs are simple to put in.
                    • mph
                      • Jan 2004
                      • 536
                      As far as I know, they are the stock shocks.
                      Current BMW's:
                      2004 330Ci
                      1986 735i
                      Previous BMW's:
                      1989 325is RIP
                      1989 325iX RIP
                      2001 740iL RIP
                      • Digitalwave
                        is a poseur
                        • 6298
                        I don't think they are much stiffer than stock. Especially on a 325i. The extra weight over the front makes the front fill a little undersprung.
                        RISING EDGE
                        • 318driver
                          • 1714
                          dont m3s and 325i's not even weigh that much different
                          I thought the m3 would be a lot lighter, but i think last time i checked they were pretty close.
                          90 325is
                          IE stage 3s and refeshed m20....
                          • Chris E30 Cab
                            • 866
                            Perhaps you would need the M3 cab springs..... the cabriolet is heavier afterall. With my Eibach Pro Kit there are cabriolet specific springs, which I assume take into account the extra weight of the car as well as how much to drop since they are quite different from hardtops especially in the rear (our cabs are already lower in the rear).
                            • 318driver
                              • 1714
                              I like the look of the eibach kit. Its not too low, and looks pretty nice. Hopefully ill see fuddys cab at the meet and get to check out in person that suspension setup(eibachs/bilsteins) and see if i like it.
                              I had thought about M3 springs but i want something more noticable in look and feel.
                              90 325is
