Eta Guys i need your help???
Here is my 86es and my 89i... which is why I said you should upgrade to a new model radiator.
1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
Make sure you have the rubber stopper installed under your oil pan pushing against the subframe and you have good motor mounts. Also, there should be a hanger that holds the hose out of the way on the drivers side frame rail. If any of those things are messed up/missing you WILL have the ALT cut the hose.:: PNW Crew ::
'87 325 4dr, '74 2002
Originally posted by backtrail69 View PostMake sure you have the rubber stopper installed under your oil pan pushing against the subframe and you have good motor mounts. Also, there should be a hanger that holds the hose out of the way on the drivers side frame rail. If any of those things are messed up/missing you WILL have the ALT cut the hose.Originally posted by e30elose the old man bmwcca badge.
OMG that video is the shit... I couldn't stop laughing when you were filming your ear...
Originally posted by bimmer_E30ok guys , i got my motor mountsOriginally posted by //MPowerAre they installed?Originally posted by bimmer_E30no, now go outside and snap a pic of your lower radiator hose.:pimp:
Your motor will then sit 2" to the right (where it's supposed to) and this will no longer be a problem.
I've been through this process already; 3 lower hoses to be exact.| Jimmy | 1999 M3 | 1986 325 ES |
I've been through this process already; 3 lower hoses to be exact.Originally posted by e30elose the old man bmwcca badge.
LOL I just thought that you could also have your alternator adjusted too far out because your belt could be too long. worth a look to see if you alternator is adjusted all the way out.
Originally posted by kenika65 View PostLOL I just thought that you could also have your alternator adjusted too far out because your belt could be too long. worth a look to see if you alternator is adjusted all the way out.Originally posted by e30elose the old man bmwcca badge.
