Jumping an e30..
  • Charlie
    kid tested, administrator approved
    • 6686
    Jumping an e30..
    Okay, I'm almost embarassed to ask this one.
    I was working on the resr suspension yesterday, and in my infinite wisdom, left the trunklid open for about 10 hours, with the light on of course. Put everything back together, go to crank the car, and *nothing*, battery's toast.
    So, herein lies my dumb question, I've never jumped an "is", with the trunk mounted battery. What are the caveats involved there? Should I disconnect anything such as the ABS sensors beforehand? My biggest question would be, where should I mount the negative cable on the 'is? IS there any issue sticking it somewhere on the frame? Obviously, it's gonna be kinda hard to reach the cable around to the engine block.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
  • Rob
    • 8166
    cant you use the positive terminal in the engine bay? I thought that was there for the purpose of jumping...
    BEERTECH
    • DanGillan
      • Mar 2004
      • 4061
      there's a terminal to jump the car in the engine compartment where the battery tray is, you'll see a little positive red "+" cover, take that off, and you'll see the terminal. you can ground to the nut on the strut tower. That's always how I do it. good luck
      Dan
        • 34839
        uhh, there is no battery tray in the engine compartment on a 91..
        I think there is a positive terminal somewhere in there though, but I've never used it. I just took mine out and stuck it on a charger.
        • Rob
          • 8166
          my 91 has a battery try, but no terminal. My 88 parts car has a tray and terminal...
          BEERTECH
            • 34839
            the ix must be different then, there definetly isn't a battery tray in my engine compartment
            • DanGillan
              • Mar 2004
              • 4061
              my 1990 "i" has a tray and terminal... use my directions...
              Dan
              • ydubbs4
                • 275
                If the battery is that dead, it wont matter. Just connect the negative to the negative terminal on the battery. Done that more than a few times with no problem whatsoever.
                Will
                • rwh11385
                  lance_entities
                  • 18403
                  lol. it's the small little things you forget about that make you kick yourself.
                  yeah, there is the terminal in the engine bay...and when I was trying to figure out why my ABS light was on when I got my car, the dealer parts guy said something about the ABS relay or something being fried if blah. I really don'kt remember, but do know he said a note along those lines.
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    Do what Dan said (man it felt weird to say that).
                    • Bokes
                      • 1459
                      when i read the title of this thread i thought it was gonna talk about actually jumping an e30 off a ramp.
                      173rd ABN
                      • DanGillan
                        • Mar 2004
                        • 4061
                        ?? um... ok why's that?
                        Dan
                        • Charlie
                          • 6686
                          Man, I dunno why I blanked on the terminal in the engine bay, Dan, thanks for reminding me.
                          First time in 7 years I've ever had to jump this car, a pretty good record I'd say.
                          -Charlie
                          FYYFF
                          • DanGillan
                            • Mar 2004
                            • 4061
                            no problem
                            Dan
                            • rwh11385
                              lance_entities
                              • 18403
                              -Charlie
