M20 Big Bore Throttle Bodies.
  • clavinZERO
    Hella sick E30
    • Mar 2004
    • 2027
    #31
    cock tease. lol.
    "BMW Style 32 Poster-Child"
    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
    • DCColegrove
      • 2748
      #32
      Originally posted by clavinZERO
      cock tease. lol.
      Yeah, I know...
      I'm looking for sources....shaft bushings, seals, ball sockets etc...
      Spent about an hour on the phone just today.
      • Miano
        • May 2008
        • 104
        #33
        about porting, are these the same profile you were doing for the group 2s in the 90s or something different?
        • DCColegrove
          • 2748
          #34
          Similar profile and surface but I'm not cutting/welding the manifold and choking down the runners.
          I 'll do those but it would cost about $600 and I doubt anyone here would be into that.
          • DSP74
            • Nov 2007
            • 1121
            #35
            I'm wondering why ITB's get a high rpm only rep. The euro S52 has ITB's and makes peak torque at 3200 and something rpm.
            Personally I'd love to see an ITB setup that would improve high rpm power, give good throttle response and boost, or at least not lose lower rpm tq.
            So many wishes. Hell I wouldn't be able to drop that much money for a couple years. To many important things to do first than to chase the last 10hp.
            88 325is
            • Justin B
              Sikky Nar Nar
              • Mar 2005
              • 4273
              #36
              I'd love to see a quality set of ITB's other than dbilas produced for the m20. I dont want dbilas first for the money, and ive heard better gains can be had by piecing one together with parts (not moto-style, like TB's from Jenvey). That's what I'm thinking of for my stroker m20, a dbilas manifold and 3 40 or 45mm DCOE flange Jenvey dual throttle bodies. If you could make something that has the ability for a compact idle control, whether its stock or not, works well, can be had without motronic software, and at a good price I may be pretty interested. Like icing on a cake.
                • 34834
                #37
                the euro S52 has vanos to broaden the torque curve, and a longer stroke than most m20s.
                typically you are going to combine ITB's with a peaky cam that will make power where that manifold is designed (short runner TB's). that means less low end torque, generally.
                • DSP74
                  • Nov 2007
                  • 1121
                  #38
                  Good point.
                  Other thing i'd like to see is an adaptation of an e manifold to an I head. Simply because of the longer runners. Increase plenum size (thickness or plenum as width would cut into the runner length.
                  A hodgepodge of e and i manifold with a sheetmetal plenum. Slightly smaller runners at the head port wouldn't be that big a deal on a stock motor. Taper port those runners larger and larger to the plenum (becoming bigger than the I intake 1/2 way back to the plenum. Then build a sheetmetal plenum, with BBTB TB opening.
                  88 325is
                  • Jand3rson
                    • 37587
                    #39
                    I would be very interested in the throttle body and manifold.
                    • Van Westervelt
                      • 9365
                      #40
                      ITBs for us 24v guys? :)
                      • Jand3rson
                        • 37587
                        #41
                        Is it not possible for you guys to fit the ITB system from a euro S52 to your engines? I've always wondered that.
                          • 34834
                          #42
                          afaik, they have a different port spacing. the euro S52 is a quite different motor altogether. S54 parts would be a closer match.. but then, why not just do the whole S54? :p
