M20 Big Bore Throttle Bodies.
  • DCColegrove
    • 2748
    If...
    I decided to produce these again how many would be interested in them at about $300 a pop.
    And If...
    I started Porting M20 Manifolds again how many would be interested at about $200 (PS they work way better than the Mud Honed bullshit).
    Also If...
    I were to produce 45mm ITB setups at about $2500 a kit would any one at all pony up for them?
    53
    Big Bore TB
    30.19%
    16
    Micro sculpted, Ported Manifolds.
    37.74%
    20
    ITB Kit
    32.08%
    17
  • e30s52
    • Oct 2007
    • 5235
    make a big bore for us 24v guys
    www.gutenparts.com
    • Jon325i
      • 6934
      What kind of gains/improments did the TB and manifold produce (together or separately)?
      Jon
      Rides...
      1991 325i - sold :(
      2004 2WD Frontier King Cab
      RIP #17 Jules Bianchi
      • DCColegrove
        • 2748
        Jon
        A well done manifold will get you about 3 to 5 HP (plus smother transitions and better efficiency due to more even cylinder charging)
        The only real advantage to big bore is top end response the curve flatens latter (like around 7 grand).
          • 34844
          ported manifold for $200 sounds like a good deal. I have one sitting under the house for a core - are they port matched to the OEM gasket? Bead blasted? I actually want to paint mine a specific color so I don't care about powdercoating.
          there's another guy who does BBTB's for a little less, he's put a lot of work into them (proper venturi, etc), but I don't know how much he replaces. I assume for $300 you pretty much rebuild it.. I also have a core to use for that, but I don't know about spending $300 on it. I think I'd rather put $300 towards exaust..
          ITBs - unless you're building a race motor that screams to 7500rpm, not worth it IMO. Tuning is more difficult and you need a wild cam/high CR to take advantage of it. Maybe somebody will bite but good luck with this crowd. :(
          so yeah - I like the idea of a ported manifold for $200. :)
          • DCColegrove
            • 2748
            Hmmm... Got any money? (large TBs are still out there for you guys you don't need me for that)
            • e30s52
              • Oct 2007
              • 5235
              depends on what day but yes i got some money lol
              www.gutenparts.com
              • DCColegrove
                • 2748
                These would be completely new units.
                I used to make them when e30 was king... I made some changes to the design in '95 (had a beter flow benches by then) and stoped producing them in 97.
                and about the manifolds: Yes they are matched and I paint them... I'm not a big fan of powdercoat.
                  • 34844
                  oh yeah, $300 for a new TB sounds better. can you make one with a reversed throttle shaft for the E36 TPS? ;)
                  any discount for a bare but cleaned manifold? I want to do mine body color. :p
                  • DCColegrove
                    • 2748
                    I'm still thinking on whether or not I'll do it at all (I hate porting...It's braindead work).
                    but if you want to try one out I might be inclined to work with you.
                    • rs4pro3
                      • 5808
                      Like Nando said ITB's are not worth it, It took me 6 years to get a set running great on my car. Yes the power is amazing, and so is the throttle response, but it's for a pure high rpm breathing engine(I run it around 4k plus all the time). If I had to do it over again I would of purchased a setup from Dbilis and saved my self the headaches, but I just don't see them being anywhere worth while on a stock engine without major mods and some sort of programmable fuel injection. I think your best bet is doing Big bore throttle bodies, and maybe a high performance intake setup with a MAF conversion, M30 AFM, larger injectors, custom silicon intake boot etc....
                      85 325e 2.7 ITB'd stroker
                      • DCColegrove
                        • 2748
                        Very true, ITB's are a bit extravagant.
                        D'bilas are nice but what I'm talking about are single units...6 45mm plates in an integral body using air bleeds to sync the idle.
                        If I reproduce them I'll tweak the design to work with 1.3 and include ICV function... New Motronic software would also be included.
                        • Danny
                          • 14216
                          m42 stuff pl0z
                          • DCColegrove
                            • 2748
                            Originally posted by Danny
                            m42 stuff pl0z
                            What do you want for your M42? ...better yet, come down here and take a ride in mine...
                            (I'm working on a new manifold porting profile right now for the M42s)
                            • Danny
                              • 14216
                              I want go fast mods for my M42.
                              I do need to get it bored/stroked.
