Where does this go?
  • Dragowl
    • 287
    Where does this go?
    So...In checking the engine bay for vaccum leaks...I found this:
    Where does it hook up to?
    Its located around here:
    And It also had this covering it...
    Also..found this...where the heck does it go?
    Any help is appreciated!
    Shameless pic of the vert!
  • Dave
    E30 RAT
    • 11675
    I think it ran and hid from that horrendous red intake manifold . . . .
    j/k
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • Dragowl
      • 287
      j/k
      LOL...possible...but doubt it... :)
      • speedhop
        • 1509
        Purge valve for carbon canister.
        www.ryanwhopkins.com
        • Dragowl
          • 287
          Hmmm...ok..thanks!
          • Julien
            • 7471
            it attaches below the intake (is your idle all funky now?) second wire looks like it is the strap for the spark plugs (goes around the front/top of the motor, attaches around a spark plug wire).. or if the car isn't running, then it's from the pulse generator by the lower harmonic balancer (big metal wheel with teeth on it)
            Best of luck,
            Julien
            Build Threads:
            • reelizmpro
              • 9534
              Charcoal canister to the nipple on the bottom of the throttle body. IIRC
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • Dragowl
                • 287
                Best of luck,
                Julien
                Yes my idle is funky...has been and I've been looking for the culprit...so does it attach to the charcoal cannister or to the intake?
                Do you have a picture of where the second wire..goes? I'll check my bentley...the car is running...idle is rough, it actually sputters
                • delatlanta1281
                  Dart Master
                  • Mar 2006
                  • 10317
                  Not sure about the wire, but the tube with the nipple attaches to another nipple attached to the bottom of you throttle body. It is a pita to get to, but when it is on just use a zip tie to keep it from slipping off. Make sure it isn't cracked anywhere as well, or your car will still act like there is a vacuum leak, which.... there is.
                  Yours truly,
                  Rich
                  you kids get off my lawn.....
                  • Dragowl
                    • 287
                    Good tip...I'll be sure to square that up...this explains the rough idle.
                    • Sean5294
                      • Jan 2008
                      • 515
                      it goes to the Flux Capacitor, Thats what makes time travel possible! :)
                      • delatlanta1281
                        Dart Master
                        • Mar 2006
                        • 10317
                        Yours truly,
                        Rich
                        • OrganicMechanic
                          • Jan 2008
                          • 1719
                          I`ll re-connect for the hardtop
                          join the E30 Cabrio owners gruppe
                          click here for details
                          • Dragowl
                            • 287
                            It can't go to the flux capacitor...I pulled that out a while back..it was malfunctioning.
                            Oh...so tempting...already done though! :)
