With the E30 M3, its a tie rod spacer correct? I know most people aren't going to do a modified steering knuckle.
I on the other hand would.
i thought bump steer came from the actual angle of the tie rod , you know, lower the car the steering rack is in effect lowered while the knuckle stay's the same height, isn't there aftermarket tie-rods available to that levels out the angle of the tie-rods back to almost centre with the rack?
Bump steer isn't only affected by the angle of the tie rod, also the length and many other factors. Raising the rack would help lessen the effects of bump steer, but not eliminate them. It also might take it back to stock (if the car was lowered), but if there is bump steer present in stock configuration, then you still have a problem.
The brace looks great. I'm curious to see what the finished one will look like.
Hey Dave, if there was a subwoofer already on place, could it still be installed? I mean is there stuff bolted down that would be under a box?
If so, shoot me a measurement of the space between the front of your trunk cage and the firewall.
I bet the new single 10 box I have been thinking of will be able to fit, and at only 35 pounds (target weight) for box, sub and amp, we might have some mutual customers.
Looks freeking awesome, BTW.
Luke
The plate you see at the bottom of the pan brace is just ahead of the spare tire well and will be less than 3" wide.
The trunk pan brace is an adition to the new shock tower brace which will be available as a stand alone. I'll try to come up with a difinitive measurement for you after the testing prototype is done.
Daniel
On a side note:
Originally posted by Bimmerman325i
I'm probably an idiot for missing it, but what about a "Safe" not-so-inexpensive solution for the bump steer and control arm issue?
Well yes... keep the ride height at the factory spec.
When the lower control arms pass parallel... You get bump steer
