Poor wet weather handling
  • Money$hit
    • Mar 2008
    • 1604
    Does anyone elses e30 handle like a pile in the rain? Even after an alignment and new tires I dont feel confident on the freeway during rain. The car feels like its all over the place. Car is lowered too.
    Idk what else to do.
  • moatilliatta
    • 6158
    get good tires.
    @Zakspeed_US
    • z31maniac
      • 17566
      You must have shitty, terrible tires.
      With the Kunho SPT's on my car I could run 80 on the turnpike in a heavy rain.
      www.gutenparts.com
      • allwheeldrive
        • Jan 2008
        • 272
        I'm in the tire boat as well. It is the only thing that contacts the road.
        • Money$hit
          • Mar 2008
          • 1604
          Falken?
          • Stevie30
            • Apr 2007
            • 1534
            Drive slower in the rain. Problem solved.
            1991 325ic and 1991 318is
            • BobombETA
              • Apr 2008
              • 1575
              Yeah, I used to not be able to go above 50 mph in any kind of rain.
              A set of good tires solved that. In the rain I used to be able to kick the rear out just by accelerating in first (I have an E)... Now it grips all the time.
              Instagram
              Current: 99 M3
              Past: 84 325e, 84 528e
              • SamE30e
                • Sep 2007
                • 4319
                R3v?
                1985 325e 2.8 Turbo VEMS
                • hendrixvodu
                  • Jan 2007
                  • 2514
                  Originally posted by moatilliatta
                  get good tires.
                  2x
                  just had a major incident because of my poor tire quality and wear ...spend the money and get good tires so you dont have to pay for body work hahah!
                  -His-
                  87 e30 325i
                  87 e24 m6
                  05 e83 x3
                  94 e32 740i 5spd
                  -Hers-
                  89 e30 325i
                  18 f48 x1
                  • hendrixvodu
                    • Jan 2007
                    • 2514
                    same prob with an m10 ...losing traction in rain thru 1st 2nd and begging of 3rd because of the tires
                    -His-
                    87 e30 325i
                    87 e24 m6
                    05 e83 x3
                    94 e32 740i 5spd
                    -Hers-
                    89 e30 325i
                    18 f48 x1
                    • DarkWing6
                      • Apr 2004
                      • 7144
                      I've run my car at the track in the rain with no problems. I would say better tires and make sure they are properly inflated.
                      • shmutzigE30
                        • 1680
                        yeah i would check your tire pressure.
                        it could help
                        AW 89' 325i Vert - SOLD
                        • geezerman402
                          • 213
                          Tires. My car came with winter tires that would slide in the rain because they couldn't channel the water out effectively.
                          • BM5W
                            • May 2005
                            • 84
                            What are your alignment specs? It is likely you changed your toe quite a bit when you lowered the car. Similarly, did you take all the weight off your rear tires by lowering the car more in the front?
                            • danv
                              • 25
                              About a month ago, I spun out in the rain with light throttle in a gentle curve in 3rd gear. I think the tires were at least partly to blame, because they were old enough to have started dry rotting even with plenty of tread left.
                              I have new tires now, and the car grips much better. I agree with the previous posters, tires are the first thing to consider.
