or can you gain more by making it a similar design, but smaller so you have more velocity VS larger bore and slower velocity
Air Induction Systems, Voodoo, and simple test
eric lukas was the original bathrobe clad god of the CAI. you guys are mere commonersComment
I did. I think you should go threw with your plans. also I noticed when I did the M30 AFM it made my car run very lean untill I did the injectors to match, doesn't that mean it flows better than the stock AFM? but I do see how a bigger door could mean a bigger restriction.
7speedshop.comComment
You're missing it...I did. I think you should go threw with your plans. also I noticed when I did the M30 AFM it made my car run very lean untill I did the injectors to match, doesn't that mean it flows better than the stock AFM? but I do see how a bigger door could mean a bigger restriction.
It's not a question of restriction but velocity...Comment
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
like a velocity stack or a venturi effect to keep the air speed up and on as straight a path as possible.
i think i get your drift. i messed around with something similar, waaaay back in the mid 90's with CIS-E on VW'sLast edited by der affe; 11-23-2008, 05:25 PM.seien Sie größer, als Sie erscheinen
lifestyle crew has you awfully uppity, post some dhno results and I'll ride your sack too.Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
Yes on the V stack to align the air initially entering the induction.
The big trick is to keep the flow accelerating in a uniform fashion from the inlet to the combustion chamber...And ultimately to the tailpipe.
The optimum is a straight line (but not a smooth bore) but not really practical under the hood.Comment
