Let's talk intake manifold design
  • z31maniac
    • 17566
    Last time we talked about cams and headwork and intermittenly touched on the intake manifold and its drawbacks.
    (If you are hear to say, stupid/don't waste the effort/you're an idiot/"You should just do a 24v swap," stop now, and don't post.)
    I'm buying matt325is intake manifold flange as a starting point for a custom intake manifold.
    Previous discussions have indicated the long runner length of the stock manifold as a one of the obstacles to high RPM flow. Basically my idea for the intake manifold is a Dbilas style setup, minus the individual throttle bodies of course.
    My two main concerns are:
    1. Size of the airbox
    2. Shape of the airbox
    1. I want to make sure the airbox is large enough and will replenish fast enough for each intake stroke of the crank. I don't know how many of you are familiar with sportbike stuff and so called "Big Bang" bikes, but for instance the new R1 uses a wildly timed crankshaft to improve smooth running etc, lots of discussion about piston speeds and throttle response and shit, but the main reason they don't just have a piston firing every 90° of crank rotation is that the airbox would not be able to refill fast enough for each intake stroke.
    2. A simple rectangle with the throttle body on the side, ie exactly like the Dbilas setup or a "house" shape with the side of the rectangle slanting outwards to long side, or even more a 666fabrication style intake (which also matches the E46 M CF airbox I think).
    What say you?
    www.gutenparts.com
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Look at eli's ITB thread, also BrownBrick IIRC at emotech have made some good m20 manifold groundwork.
    • atomic
      • Jun 2007
      • 5691
      /thread
      • kronus
        • Apr 2008
        • 13032
        TurboBrown. His project thread is amazing.
        cars beep boop
        • StereoInstaller1
          GAS
          • 22679
          stupid
          you're an idiot
          hahahaaahahahaaa
          OK, If I were to make my own intake manifold, it seems to me all of the race guys use individual trumpets. www.kinsler.com used to sell trumpets, but good god, look at the fucking fuel pump on their start page!
          I wonder how hard it would be to use 6 trumpets inside of a plenum made of acrylic? The mouth of the trumpet can't be against the wall of the plenum or there will be too many reflective waves affecting the airflow.
          Anyway, I think the biggest thing to deal with would be the resonant frequencies and how to spread them out so you can have decent flow characteristics across the board, RPM wise. If you design and build for 8K RPM and the thing does not flow well below that (AKA too high of a resonant frequency) you will loose all bottom end.
          Is this thing gonna be a driver or WOT race car or what?
          Closing SOON!
          Thanks for 10 years of fun!
          • Julien
            • 7472
            stupid/don't waste the effort/you're an idiot/You should just do a 24v swap :-D
            and seriously, I wouldn't touch it as the intake runner length is very finely tuned for a motor/application.. there is a ferrari video out there somewhere where they have variable intake length manifolds to provide a flat torque/hp curve
            Build Threads:
            • z31maniac
              • 17566
              Julien, I see your point, but the intake manifold was designed for a stock M20 as it came from BMW, not a bored, stroked, and cammed M20.
              I want to build a high-comp 3.1L M20, so headwork/cam and everything geared for 4k-7k operation means I would want the intake designed with that in mind as well.
              Street, auto-x, HPDE car. I'm willing to give up low RPM power for high RPM power and throttle response.
              www.gutenparts.com
              • DCColegrove
                • 2748
                PM me...
                No matter what you think...
                This is something I know something about.
                • Julien
                  • 7472
                  Yeah but what I was trying to say with my post is that I don't see you building a better suited one in a shed.
                  Build Threads:
                  • z31maniac
                    • 17566
                    ^Fair enough, but I'm still going to give it a shot.
                    www.gutenparts.com
                    • Tree18is
                      • Mar 2004
                      • 2703
                      just pack it full of boost, all those sheetmetal intakes seem to work fine. Im a big fan of the s38 manifolds you usually see on a turbo motor.. Some how it works just fine and makes a shit ton of HP
                      • moatilliatta
                        • 6158
                        Variable intake
                        @Zakspeed_US
                        • DCColegrove
                          • 2748
                          Originally posted by moatilliatta
                          The truly hot setup... Not simple though... I've been toying with the idea of a staged manifold using a progressive throttle body (similar to the m42s or 4bbl vacuum secondary carb set-up) for a while now... Somebody should try it.
                          • moatilliatta
                            • 6158
                            it would be interesting on a straight slant six, you could use the slant of the motor of the motor for the est lengths of the runners and possible have to plenums with something connection them and throttle body. got the idea in my head, just not with words.
                            @Zakspeed_US
                            • DCColegrove
                              • 2748
                              I get it...
                              I was thinking more on the lines of a manifold within a manifold...
                              You would need an HFM type MAF setup to make it work right... The transition would play hell on a AFM...
                              I was looking for a Miller MAF a little while back just to play with this idea and even contacted Miller... But no dice... Don't even really have the time for it anyway.
