Smooth Valence
  • shmutzigE30
    • 1680
    Smooth Valence
    ok so i know bmw used aluminum valences on the late models and all the ones ive seen around me had a bumpy texture to reduce rock chip visibility.
    my question is that often i see people on the forum with smooth ones and im wondering if theyre after market or modified originals??? and has anyone ever molded an is lip into the valence?????
    Thanks
    AW 89' 325i Vert - SOLD
  • shmutzigE30
    • 1680
    and ive searched and found this but is it the only way??? ahhhhh
    Part II - The Abject failure of Aircraft Stripper...
    Today (09/24/06), we began stripping the rubberized undercoating off of my late-model front valence. Well actually, we sort of started yesterday. What we had planned to do was soak the paint/rubberized crap with Aircraft Stripper. I was told by several people that this shit would turn the undercoating to goo, and we could just scrape it off with a putty knife.
    WRONG! It didn't work, it hardly even softened it up. So what do we do? Go back to Harbor Freight and buy a $5 wire wheel and strip the shit off with a Makita grinder, that's what!
    This stuff no workie. Should have guessed, $4 a can at Wal-Mart...
    The front valence, before stripping. See at the left of the vents where we tested the grinder. It worked real good...
    Andrew going to town on the paint/undercoating. The wire wheel stripped this crap off like it wasn't even there:
    One side completed. In the large flat areas, this shit was really thick!
    Like I said, THICK. This was after about 3 minutes of stripping this area.
    Stripping of the bumper mounting area. About halfway up, the undercoating stopped and it was just paint. VERY easy to remove:
    Finished with the lower portion of the valence:
    The finished, stripped, smoothed valence. Smooth as a baby's behind. And I should know, I've got one to check it against!
    It might not look it in these pics, but this thing is shiny and VERY smooth:
    • 88e30is
      • Feb 2007
      • 690
      I have a smooth one. It has a rubber like paint on it. Like rhino liner or something. Strip it, prime it, paint it. IS lip goes right on.
      • kronus
        • Apr 2008
        • 13029
        I cannot agree with Janderson's experience, but maybe the aircraft paint stripper I used was of a better quality.. it took the paint right off my valence, with no problems. I then primered and painted the bare metal, and now have a smooth valence.
        cars beep boop
        • shmutzigE30
          • 1680
          so the aircraft paint stripper got rid of the bumps??? or did you have to do something after that
          • kronus
            • Apr 2008
            • 13029
            Well, yes. The metal is smooth, because it's sheet metal. They use a textured, lumpy primer on the valence and rocker panels so that it hides dirt, scratches, and small dents that would be evident on a smooth finish.
            cars beep boop
            • Raxe
              • 5346
              Gets rid of the paint too.
              • guibo09
                • Dec 2008
                • 834
                how bad does it look if you keep the textured valence and ad a smooth IS lip?
                90 E30 325i
                • shmutzigE30
                  • 1680
                  +1
                  can someone PLEASE post an up-close pic with a textured valence and smooth lip, painted or black anything will help???
                  • dannyg
                    • Mar 2007
                    • 1553
                    Not bad at all...
                    I want to keep the car as original as possible, so I just added the IS lip.
                    1993 325ic Schwarz/Natur
                    1991 318is Black/Black - Slicktop - Project s52
                    1989 Alpine White/Black M3 S52
                    1988 Henna/Pearl M3 <3
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      +1
                      90% of the cars with an iS lip look like this. Go search Members Rides.
                        • 34839
                        the late valance is not aluminum... unless aluminum rusts like steel does.
                        • guibo09
                          • Dec 2008
                          • 834
                          yeah didnt the 318is and 325is come from the factory with textured valance and smooth lip? or was the lip textured also?
                          is there a way to recreate the same texture? i think i would consider doing that with the lip.
                          90 E30 325i
                          • E30FreaK89
                            • Apr 2006
                            • 437
                            no the IS lip would'nt come with texture from the factory. but i would assume that the valence when brand new off the boat would be very glossy and fresh and you would'nt even be able to tell.
                              • 34839
                              the textured valance with new paint looks just fine. most people have sandblasted/chipped/bent valances so they look like ass.
                              and don't texture the lip, I've seen it before, it's not attractive.
