I hope its not dead...
  • dager325
    • Nov 2007
    • 185
    So I was driving my car home from a friends house today and the engine almost started clunking. Stupidly I drove it home. I had no clue what it could have been, so when my dad came home had him listen to it and he said it could have thrown a bearing or the oil pump might not be getting oil to the rocker arms and what not. I know this is very general but if anyone has any clue please help me out. I miss that thing and its only been a few hours without driving it.
  • Alkasquawlik
    • 4557
    youre prolly going to have to be more specific
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
    • dager325
      • Nov 2007
      • 185
      Temp was fine, oil was a little low, added a quart and didnt help any. I have no clue what it could be.
      • dager325
        • Nov 2007
        • 185
        I am reading the Bentley right now and sounds like it could either be values need to be adjusted, rocker arms broke, or cam bearing went.
        • Charlie
          kid tested, administrator approved
          • 6686
          If you're trying to have a contest between who can guess your problem: The internet with your vague descriptions, or you with physical access to the car, I think you will win.
          Take off the valve cover. Should be pretty obvious.
          -Charlie
          Swing wild, brake later, don't apologize.
          '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
          FYYFF
          • mikekristine325ic
            • Nov 2008
            • 338
            Originally posted by dager325
            I am reading the Bentley right now and sounds like it could either be valves need to be adjusted, rocker arms broke, or cam bearing went.
            Corrected^^^^^^
            Does it sound like a hammer hitting metal or is it more of a clicking (Valve Chatter) noise. Also, check to see if it is louder from the bottom of the car or is it louder by the valve cover. If it is louder from the bottom, most likely a spun bearing or dropped cylinder. If from the top, open up the valve cover and check your rocker arms, retaining springs, valve height, etc.
            IF this doesn't fix anything, PM me. My uncle is a BMW mechanic and his brother owns a BMW Dealership so I will definitely get answers for you.
            sigpic...
            1991 325is- Current Project w/ 150k on the clock
            1990 325ic- SOLD w/425k on the clock and still ran!
            1985 528e- SOLD
            1972 2002tii-Should have never sold it!
            • Money$hit
              • Mar 2008
              • 1604
              look under valve cover. report back.
              • dager325
                • Nov 2007
                • 185
                I just in from working on it. I compression tested it, all were fine. Check valve clearance they were also fine. Rockers look fine. Noise is definately sounds like its coming from the top of the engine. Its more of a ticking noise but that doesn't make sense if the valve clearances are fine.
                • Streichholzschächtelchen
                  • Jan 2009
                  • 1670
                  Adjust your valves...
                  Jah bless! :pimp:
                  • dager325
                    • Nov 2007
                    • 185
                    Can you read?
                    • kamotors
                      • Nov 2007
                      • 7102
                      m20's naturally tick,maybe you could record it on video so we could help diagnose it better.
                      7speedshop.com
                      • Moto-Mucci
                        • 2058
                        Def pull the valve cover off. It only takes like 15min. Check for things that look not good.
                        • PhillyG
                          • 754
                          Newbies with awful descriptions.
                          • Moto-Mucci
                            • 2058
                            ...or we could try to help him out.
                            • dager325
                              • Nov 2007
                              • 185
                              I know what you mean. It would do that a lot but now its a lot louder. It sounds very similar to this:
