16x8 et25?
  • =======Live Fast!
    • Nov 2011
    • 248
    16x8 et25?
    Curious if we can run a et25 offset on a square setup without any issues.
    sigpic2000 323ci
    1987 325is super etta
    1988 M5
    2000 M5
    1989 944 turbo
    1989 325is
  • Shangsta
    • 1485
    That might be too close to the strut. You may need a small 5mm space to clear
    :shock:
    • bradmer
      • May 2016
      • 362
      Tha Apex ARC 8 flat face 17" wheel is et 25, I run that square with 235/40 tires. Fenders rolled and liners pulled, the rubber not the wheel does rub a bit on the fender on track days.
      • E30 Wagen
        • Jul 2005
        • 3428
        Not sure if this helps but I ran 16x7.5 et20 with no issues, can't remember if the tire was 215 or 225 or how close it was to the strut. Car was lowered slightly, no rubbing.
        My Feedback
        • Northern
          I like cupcakes & sh!tboxes
          • 5231
          Should fit fine. 19x9 ET15 is danger close and sometimes needs a spacer, but those should clear by like 3mm more.
          Originally posted by priapism
          Originally posted by shameson
          • AWDBOB
            hooptie connoisseur
            • Aug 2013
            • 4469
            I run a 215/45 on a 16x8 et13 with no rubbing. 16x8 is pretty much perfect, you could probably get away with a 225/45.
            • AWDBOB
              hooptie connoisseur
              • Aug 2013
              • 4469
              I run a 215/45 on a 16x8 et13 with no rubbing. 16x8 et25 is pretty much perfect, you could probably get away with a 225/45.
              • =======Live Fast!
                • Nov 2011
                • 248
                So I ended up buying a 16x8 et20. It hits the calipers. They're going back.
                sigpic2000 323ci
                1988 M5
                2000 M5
                1989 944 turbo
                1989 325is
                • AWDBOB
                  hooptie connoisseur
                  • Aug 2013
                  • 4469
                  that also has a lot to do with spoke design. Unless you have a low clearance BBK, a small front spacer for caliper clearance is usually required
                  • =======Live Fast!
                    • Nov 2011
                    • 248
                    I'm bummed. I don't want to run a spacer at all. If anyone has suggestions besides a Beyern mesh for a deep dish wheel, let me know.
                    sigpic2000 323ci
                    1988 M5
                    2000 M5
                    1989 944 turbo
                    1989 325is
