Control Arm or just Ball Joints?
  • Westija
    • Aug 2015
    • 90
    Any specific reason why most DYIs refer to the replacement of the entire Control Arm instead of just its Ball Joints? I get it that it requires a C-Clamp tool but isn't it available for rent in most auto parts stores? Or yet, I think one can buy the tool with the price difference.
    I am getting ready to do this and want to be sure I am not missing anything.
    Thanks
  • roguetoaster
    Biggus Tippus
    • 7830
    Typically, the ball joints are just under $80 for all four for decent units, and a pair of control arms can be had for $160. Considering how the splines can get damaged, how the clips can get seized, how it's just rather annoying, and can significantly delay your project if you run in to any of those things, the extra $80 makes sense to me.
    ​​​​​​I suspect the best justification for doing ball joint replacement alone might be if you had two or three sets around that you wanted to do at one time.
    • Vincenze
      • Apr 2019
      • 1039
      You'd better buy a Harbor Freight press for the ball joint replacement job in addition to the assortment of pipe adapters from the ball joint kit.
      You'll need some tools to insert new bushings into the lollipops (a press can work), and to remove and install back the lollipops.
      And tools to unscrew the 22 mm control arm nuts.
      It's already time consuming to build or buy those tools.
      • ZEKTI
        • May 2016
        • 218
        If you have the tools sure you can replace the ball joints, if not it’s easier to just buy a new arm. Personally I’m in Midwest and prefer one that’s newly painted, so I opt for new. But you could make MeyleHD on the cheap yourself. Sent from my iPhone using Tapatalk Pro
        OBD1 S52 E36 Compact
        84 318i M10 Zender
        • ForcedFirebird
          • Feb 2007
          • 8300
          The outers can be done on the car. That's a huge benefit if you are just replacing a worn one. Quality control arms cost about $100ea, inner ball joints are $25, outer $20. So, if you already own the tools, it's a no-brainer - but if you are paying a shop, the money saved on parts is eaten up by the labor, so it's generally a wash at the shop. That being said, I have replaced hundreds of them.
          john@m20guru.com
          Links:
          • Westija
            • Aug 2015
            • 90
            Thanks everyone. Good to hear different perspectives.
            • jeffnhiscars
              • Jun 2011
              • 6011
              the last couple of sets of lemfoerder control arms I bought were in the $70-75 range per arm. Makes no sense to fuck around with used arms, presses etc etc
              Alice the Time Capsule
              • Victell
                • 1083
                Its a good time to replace lower control arm bushings as well.
                • Jordan
                  • 12916
                  With how cheap full replacement control arms are from legitimate companies it just makes no sense.
                  The sole exception to this I feel is the 96-99 E36 M3 control arms, which are $300ea+ but E30 ball joints press right into.
                  https://mtechniqueabs.com/
                  • e30strokr
                    • 211
                    you can also make your own 'lollipop into control arm' tool by going to home depo and getting some nuts and a "threaded stick" along with a couple of flat steel plates....$30 tool ...
