Need help picking a good car
  • Raffefaste
    • Jan 2021
    • 4
    Im new to the car community but I've found that I really like old bmws but don't know enough to identify stuff. These are some listings I've found and I was wondering if these are good and how much work they would need to be pretty good
  • twright
    • 707
    We're going to need more info than that. Can you provide more pictures and more detail of the two cars you are interested In?
    • Raffefaste
      • Jan 2021
      • 4
      • Vincenze
        • Apr 2019
        • 1030
        One is a 4-cylinder E30. The other is a 4-cylinder M10 E21.
        You should first check if a car has a perfect body with no rust. That's the main priority.
        Here is the Buying guide https://www.rtsauto.com/e30-bmw-buyi...d-from-german/
        • KI4UJO
          • Jun 2011
          • 642
          As stated above, I would definitely prioritize the condition of the body shell over everything else. After all, the other stuff bolts on. Having had both an m42 and an m10, I will say that the m42 is definitely a more engaging engine to drive - mostly as the m10 was designed for a lighter car.
          IMG_0145 by Jonathan Martin, on Flickr
          • MR E30 325is
            • Dec 2008
            • 3300
            At this point in the E21/E30 lifespan, teamed with your newness, the condition of the body should be your top priority. Rust is a big no-no to tackle. Like KI4 said above, everything else bolts on.
            My previous build (currently E30-less)
            http://www.r3vlimited.com/board/showthread.php?t=170390
            A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
