My 318is 24v swap
  • bmwfan52
    • May 2016
    • 118
    My 318is 24v swap
    I just realized I may have not posted one of my main builds.
    so here is the latest shot of her.
  • 2mAn
    Señior Mod
    • 20924
    More info!
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
    • roguetoaster
      Biggus Tippus
      • 7830
      Is this some sort of strange design of truck? It is 2021 after all.
      • Northern
        I like cupcakes & sh!tboxes
        • 5264
        Originally posted by 2mAn
        More info!
        Originally posted by priapism
        Originally posted by shameson
        • bmwfan52
          • May 2016
          • 118
          I bought this 318is stock(formerly ka "my Prius") in 2014 drove it along with my 1999 e36 m3. Then when my M3 got T-boned I started the idea of swapping the motor into my Prius.
          Pros of the 318is it still has its original paint, zero rust, and no shocks tearing thru the body like my M3
          Cons it didn't come with power door locks which was a first for me(considering that I have owned over a dozen E30s over the years) I'm thirty friken 8 in 9 minutes.) also at this point the car has a few jack and hoist dent bellow the belt.
          Now about the swap, over the past five years, I tried just about everything to get the car where it is today. Tried the m50 intake and chucked it for the obd2 setup, had 14" momos, 15" ACs, had a m3 muffler at first with the resonator, which didnt last very long.
          suspension I went from Raceland I know don't laugh, then H&Rs.
          the cooling system went from fan clutch and e30 radiator to the setup I am running now, I am getting to that next.
          Current set up that is tried and true
          It's officially my birthday now and I am done typing for the night I will be heading to the dive bar as of now.
          • 2mAn
            Señior Mod
            • 20924
            Well, happy birthday.... but ....
            some of your birthday shenanigans are also welcome
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • roguetoaster
              Biggus Tippus
              • 7830
              Just don't go full Burgundy, whatever you do.
              • bmwfan52
                • May 2016
                • 118
                Cool so I’m back for part two and some pics.
                so
                • bmwfan52
                  • May 2016
                  • 118
                  I spent a good amount of time on my phone last night posting and responding to replies and today it's nowhere to be found.
                  But I said I am going to show you a tried and true way to this setup and I am going to stick to it.
                  Stay tuned cause from here on I am going to use my PC to post.
                  • bmwfan52
                    • May 2016
                    • 118
                    • bmwfan52
                      • May 2016
                      • 118
                      Finally found a post that sheds light on my BBK here https://www.r3vlimited.com/board/for...ood-e30-brakes .
                      Apparently they are old school, and made for the e30, so you don't have to go 5 lug swap to get BBK.
                      They look ravishing even with the battle scars.
                      To clarify they are RPIequipped BBK made by WILWOOD
                      • bmwfan52
                        • May 2016
                        • 118
ID:	10027680 Exhaust system is obviously custom I had two separate muffler shops do my setup the last place installed a woven flex pipe leaked fumes into cab then hit this ridiculous bend
                        last week welded it myself and I have zero complaints
                        • bmwfan52
                          • May 2016
                          • 118
                          I was running with a bent fuel are pipe until I realized I can just cut the pipe out and replace it with a rubber fuel line. Car starts right away now.
                          • bmwfan52
                            • May 2016
                            • 118
                            M42 radiator if you want to be able to bleed the cooling system fast and easy. Resovour is attached to it and out of the way.
                            you just have to plug a few line leading to tb and engine
                            shit part is it’s very close to ps pump bolts
                            • bmwfan52
                              • May 2016
                              • 118
                              Better pic of radiator
