Just another vert. A white one.
  • Driftin
    • Jan 2011
    • 129
    I haven't posted here in forever. Makes me happy that a real forum is still active and is still the best source of information for the e30. Maybe I am old now, but man, Facebook suuuucks. Instagram suuuucks. Anyway, I have had this white 91 convertible for a quite a while now, and it is time for it to get it's own thread for no other reason than I want a place to document my time with the car. I bought this car on Friday April 12 2019 on a business trip down in Phoenix. After work I hopped on craigslist, and bam, there it was. White e30 convertible, runs well, needs some work, slight damage to front end. I went and checked it out, looked alright to me, so met up with the guy again the next day and handed him $3600. Skipped my flight back home to SLC, put the top down, looked at the rainbow overhead and started heading north. Success.
    The drive back to SLC is a great way to get to know a car. Wide open space, no traffic, beautiful scenery. Little chilly in April, but that is what jackets are for. Made it back to SLC where I parked it next to it's older sibling the he53 540i.
    Over the next few months, it got the timing belt changed, the front ding repaired, and the seats reupholstered. Check out the little euro fleet.
    Click image for larger version  Name:	IMG_20190412_184536.jpg Views:	0 Size:	161.6 KB ID:	10131494
    Click image for larger version  Name:	IMG_20190413_175532.jpg Views:	0 Size:	164.8 KB ID:	10131496 Click image for larger version
    Click image for larger version  Name:	IMG_20200925_164232.jpg Views:	0 Size:	163.7 KB ID:	10131497 Click image for larger version  Name:	IMG_20200321_112149.jpg Views:	0 Size:	165.0 KB ID:	10131498
    More to come bringing it to current day.
  • Driftin
    • Jan 2011
    • 129
    The car came with a folder full of records and receipts including receipts for bilstein b8 and h&r springs. So that is a good start. The seller also included a new set of ST swaybars and all hardware. So got those installed.
ID:	10131515 Click image for larger version
    • Driftin
      • Jan 2011
      • 129
      Chinzy ass ground straps must go. Make your own beefy sealed from the elements one. Replace the timing belt and get some seat covers installed. The seat covers were perforated leather from Lseat. The quality is so so. I probably would try something else in the future. I put them on about 4 years ago, and I admittedly have left the top down in many situations where I should not have, but I am fairly disappointed with how they have held up.
      Click image for larger version  Name:	IMG_20190709_222821.jpg Views:	13 Size:	172.8 KB ID:	10131520 Click image for larger version  Name:	IMG_20190709_191520.jpg Views:	14 Size:	168.0 KB ID:	10131524
      Click image for larger version  Name:	IMG_20190529_215045.jpg Views:	14 Size:	116.1 KB ID:	10131522 Click image for larger version  Name:	IMG_20190604_225042.jpg Views:	14 Size:	168.5 KB ID:	10131523
      Click image for larger version  Name:	IMG_20190529_215033.jpg Views:	14 Size:	159.3 KB ID:	10131521
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        Are the new covers also from Lseat?
        Originally posted by priapism
        Originally posted by shameson
        • Driftin
          • Jan 2011
          • 129
          Yeah, they are L seat. I'll have to take some updated pictures of how they have worn. The rear seat bottom leather is failing. I am not the best about putting the top up when I am not driving the car, as it generally doesn't rain very often in the summer out here, but I'd give the quality a solid, meh, it's ok.
          • Driftin
            • Jan 2011
            • 129
            So after getting it running pretty well, I drove it and drove it and drove it for the next couple of years without too much issue. Driveline clunk? meh, whatever. Rear end clunk? meh whatever. Then it began to stall occasionally, and get weird idle, and an occasional check engine light. I forget the code, but it was a mixture code. I traced the leak to injector orings. I pulled the injectors, took them to a local shop who gave them a solid cleaning and flow test before and after. solved my mixture problem, and made er hum again.
ID:	10132050 Click image for larger version
            • Driftin
              • Jan 2011
              • 129
              The driveline clunk and the sloppy shifter, and the oil pan leak, whatever. What finally led to the last bit of work, and really gettin the car tight again was a clunk that developed in the steering. That needs to be addressed. So I dove in. The result was a big pile of parts to install. I mean, while you ar in there, ought to do x, and y, and z, and..... My wife loves it when I spread parts around the living room while watching hockey!
              I was able to locate the source of slop to the ujoint and flex disc area of the steering column. I pulled the joint and upon further inspection discovered that the rubber flex disc, while soft was ok, but the plastic centering bushing was not. There was slop in the steering column where it inserts through the flex disc into the upper half of the ujoint. There is a small plastic sleeve that slides into the metal upper u joint piece that centers the steering column shaft. The shaft had play in the sleeve, and would knock back and forth ever so slightly (felt more than slightly in the car) creating a clunk at the steering wheel. I couldn't find a sleeve to replace it, and a used ujoint assembly is pricey and who knows if condition is any good?!?! so I went with amore solid connection to the wheel and bought a garagistic poly flex disc. Much more solid connection.
ID:	10132056 Click image for larger version
              • Driftin
                • Jan 2011
                • 129
                Along the way, my daughter decided that we needed to clean up the emblem on the trunk.
                So i let her at it. We'll keep it like this.
                • Driftin
                  • Jan 2011
                  • 129
                  So, while we were in there with the steering column, I decided it was time to install the oil pan that I have had sitting in a box for the last 3 years or so, and get the cracked JB welded cludge job out of there. It was like that when I got it, and it never leaked too bad! But yeah. Lets get that sucker out and a fresh one in. I used a harbor freight engine hoist. Lifted the engine from the top a bit. Dropped the subframe a bit on the bottom, and held it in place with longer bolts. I was able to clear the oil pump pickup easily, and was very easy to do. People make this out to be a lot harder than it actually is. I used a cork gasket because that is what I had laying around.
ID:	10132074 Click image for larger version
ID:	10132076 Much Better.
                  • Driftin
                    • Jan 2011
                    • 129
                    Next on the agenda was driveshaft. So I yanked it out of there. It had a pretty good clunk going on where the two pieces connect, and the whole thing needed to be replaced. So. Texas driveshaft specialists came through... http://www.driveshaftspecialist.com/
                    Showed up super fast, was around $550 delivered I think? Very reasonable. We'll see how it holds up. But it does appear to have rebuildable ujoints. so that is good. After I yanked the old one out I figured I ought to do the shifter bushings as well since they are accessible. So I ordered up the garagistic rebuild kid and slapped it in. The rear shifter carrier bushing was TOAST. Like completely failed. So, rebuild shifter, install. Install driveshaft.
ID:	10132080 Click image for larger version
ID:	10132082 Click image for larger version
                    • Driftin
                      • Jan 2011
                      • 129
                      And to just about bring us current, I had to replace the rear sub frame bushings. They had also failed, and were clunking. Again, these get made out to be a nightmare on the convertible, and they just aren't that bad. Worst of it is drilling out the prior bushing remnants from the frame. That was the most time consuming piece of the whole ordeal. I used the torch and socket method to remove the old bushings, and they were pretty much toast. The Ireland Engineering bushings went in nice and easy. No pics, but an Ireland Engineering strut bar was added to the engine bay to help tone down the cowl shake. The x brace from garagistic only just arrived, so has not been installed yet.
ID:	10132085 Click image for larger version
                      And, we are ready for a test drive! I headed out to Immigration Canyon which is right by the house. With the top down it got a bit chilly, but the handling on the car was radically improved with all the work completed. The rear end felt nice and tight and composed with the rear sub frame bushings replaced, and the steering was fantastically connected compared to the soft rubber flex disc and play it allowed. The IE strut bar made a huge difference in chassis flex, and the car was overall much more enjoyable to drive.
                      A few more bits have continued to roll in.
                      The Garagistic x brace arrived, and I assembled it. Quality looks decent, however I did have to chase the threads on one of the holes with a tap as it was not quite finished from the factory. Really looking forward to the increased rigidity this will provide.
                      Sitting around thanksgiving with the in laws back east for turkey where it was cold and rainy meant lots of time watching football and surfin the web looking for car parts, and wouldn't you know. I found some. And they are arriving. Pelican had some weird deal on some of the Maxilites, so I grabbed a square 16/7 setup of Alpina reps. $220 a piece delivered. Bam. I am going square, not staggered, because while you can find good tires in 205/50/16, and good tires in 225/45/16, you can't find them in both. And I ain't about maxin out my stance with wide tires, I just want something that is easy to fit and makes the car fun to drive, I went with the 16x7. Oh and did I mention I found a deal on them?
                      • 2mAn
                        SeƱior Mod
                        • 21076
                        Its going to look great with those wheels, and Im all for a square setup. Thats a fun cruiser, not a time attack racer. Coming along nicely!
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • Mike36
                          • 1079
                          Following
                          • Tzantushka
                            • Nov 2018
                            • 390
                            Looking great.
                            And looking forward to your thoughts on the X-brace.
                            Their older bolt together version looked janky.
                            E30 320i vert
                            But daily drive is Volvo V60 Polestar
                            • 82eye
                              • Jan 2009
                              • 2108
                              cool car. nice work. those wheels are gonna transform the look.
