E30s on 16s - post yours
  • NickL
    • 562
    #1651
    Originally posted by Jim Lepage
    Sweet ! What wheels are they ?
    They look like 3 pcs Enkei NT03.
    CCW D11L Jim,
    Ignore my crooked ass stupid euro plate
    1987 325is - S52
    • LJ851
      • 7919
      #1652
      Originally posted by Acehye559
      Fuck it, iphone pic...
      Hot Damn, those are sexy !
      Lorin
      The M30 is God's engine.
      • Jim Lepage
        • Jul 2008
        • 1138
        #1653
        Originally posted by NickL
        CCW D11L Jim
        Thank you Nick.
        They're pretty !
        E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
        • Acehye559
          • 1033
          #1654
          Thank you Nick.
          They're pretty !
          Thanks Jim
          • thatphysicsguy
            • Mar 2013
            • 843
            #1655
            My car will be sitting on these guys come springtime!
            '91 325i
            • lambo
              Captain Scene Points
              • 10953
              #1656
              • alpineII_dirty
                • Apr 2012
                • 186
                #1657
                Excuse the quality, my 4s lens is scratched lol
                • studawg
                  • Nov 2013
                  • 39
                  #1658
                  Originally posted by Hugo Stiglitz
                  He's absolutely right. The clamping force of the lug hardware holding the wheel face to the hub is all that's needed to keep the wheels centered. I had my Apexs mounted to the rear hubs with 10mm spacers that left no measurable length of the centerbore going into the wheel hub, and my wheels were perfectly centered. Not a single vibration or anything, tested up to 90 mph. Same with my current wheels.
                  You will get people trying to tell you that the hubcentric rings are intended to take the load off of the lug hardware and onto the hub center. If this were true, hubcentric rings made of plastic would be less than useless. The entire weight of your car is NOT resting on the lug hardware. Their intention is to fill in the extra space around the hub and the centerbore to ensure that when you bolt up your wheels, they are in the perfect position.
                  From Turner Motorsports website:
                  Hubcentric Fitments All BMWs use hubcentric wheels. When mounted to the car, the wheel rests on a lip instead of the wheel bolts or studs. The lip contributes to the strength of the wheel and the wheel cannot safely be used without a lip. The wheel bolts are not strong enough to support the weight and loads generated through the wheel. The lip is usually 9-10.5mm in depth and the new spacer must have its own lip. Turner and H&R Spacers with their own integrated hubcentric lip are: 10mm, 12mm, 12.5mm, 15mm, 18mm, 20mm, 25mm, and 30mm.
                  Are you saying that TMS is wrong?
                  1988 325i 4dr/5sp Lachssilber Metallic/Black Leather
                  2003 540iT M Sport, Black Sapphire/Black
                  • kronus
                    • Apr 2008
                    • 13032
                    #1659
                    You know how plastic hub centering rings are really fragile? It's because the material is very stiff and doesn't deal with bending very well. it does, however, deal with pressure very well as it is completely incompressible, which is why it is used for hub rings.
                    Vibration is not what hub rings are aiming to solve. Bolts/studs have not changed since the 70s, but cars have gotten substantially heavier. It's a reinforcement.
                    cars beep boop
                    • DIIRTY-30
                      • 1665
                      #1660
                      BLUE NOSE - M62 SWAP
                      THE E30 + 1 BUILD
                      • logyt
                        • Aug 2012
                        • 176
                        #1661
                        16" epsilon southernways
                        IMG_3281 by logyt, on Flickr
                        my e30
                        http://www.r3vlimited.com/board/show...=274651&page=3
                        • DatUtahGuy
                          • Jan 2007
                          • 3146
                          #1662
                          Holy win batman ^^
                          <3
                          YOUTUBE: AR Perez
                          If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
                          • MPLFoster
                            • May 2013
                            • 1490
                            #1663
                            ^so jelly...lookin' good, man.
                            wish mine were 16's.
                            form.follows.function IG @mplfoster
                            • IRUNEDM
                              • Oct 2009
                              • 1122
                              #1664
                              gorgeous!
                              Feedback
                              Instagram - @e30_mtech2
                              • ak-
                                • 12422
                                #1665
                                Much better than the d90's or whatever those Porsche wheels are called.
                                New valance and your car is kickin'
                                1991 325iS turbo
