My Quest for +1 Lug...
  • jahnaboi
    • Oct 2006
    • 1742
    #31
    Full setup as follows:
    Front:
    1998 M3 Front Assembly (Complete)
    spliced in e36 m3 abs sensors to e30.
    Using e30 top hats + e30 strut bearing
    Using stock e30 spring pads
    Treehouse CAB
    IE3 springs
    E36 Koni Yellow Top Adjustable Front Insert
    E30 M3 Sway Bar Links
    Rear:
    1995 318ti Trailing arms with e30 axles + e30 abs sensors.
    E36 M3 Koni Yellow Top Adjustable (from GC kit)
    IE street TAB/IE Race Subframe Bushing
    GC RSM for e36 M3
    But yea, anyone got any info about the fender linings? Should I just remove them?
    -Jasper
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • 37829
      #32
      Looks fucking great Jasper! I'm loving the way ti looks with the DS2 wheels and meaty tires. Are your front springs cut at all? Seems damn low for IE3.
      Also, I'm glad I stand corrected on the 318ti information, I was misinformed. Either way I sold my 318ti parts and swapped to M Coupe, lol.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Jesse30
        • Jan 2007
        • 3936
        #33
        +1 thats reaaallly low for IE3's
        • jahnaboi
          • Oct 2006
          • 1742
          #34
          Thanks! The dsIIs are temporary while I refinish my other rims. I'm borrowing them from a friend. Although I will be running 235/40/17s with my other rims. Just want a slight stretch on a 9" rim.
          Yes, I cut 3/4ths of a coil on my springs 3 year ago when I was irritated by the reverse rake.
          No problem about the 318ti parts correction. I've read many different things, and the only way I could find out literally was by doing it myself. I want m coupe stuff.
          • Tonys18t
            • Sep 2009
            • 943
            #35
            did a little fender work on the car recently, this thing is hot, that suspension sits just right.
            PBMW Magazine. PVW Mag
            Fender Rolling for dirt cheap in SoCal. Hit me up.
            Check out my work...
            http://www.r3vlimited.com/board/showthread.php?t=165114
            • Spaz
              Crazy Canuck
              • 2276
              #36
              Looks great, but im curious about the rear shocks....aren't the e36 shocks too long for e30's? To the point where you'll be bottoming out on them frequently.
              -Cam
              Cam .W '91 325is
              Spaz's 1991 Alpine White???? S52 Build Thread...
              • jahnaboi
                • Oct 2006
                • 1742
                #37
                -Cam
                Semi-Solution.
                I still want to fab a 1inch spacer and reinforcement plate for safety. But for now, these work.
                • jahnaboi
                  • Oct 2006
                  • 1742
                  #38
                  Haha. Shits low. But yea, need a tad bit more massaging on the right rear and its perfect. =) Thanks again Tony. Pleasure meeting you as well.
                  • aSpecD_
                    • Jul 2008
                    • 495
                    #39
                    Looks pretty perfect Jasper. So with your DSII's you were able to fit 245's and 235's with the stock 41 offset right? cause when i was running the DSI's with my low offsets, due to adapters depth, I was rubbing a lot. I had to re-roll after all the rubbing it did going to Bimmerfest '09. Anyway, I only had 205's on my 17x7.5 and still had to remove the fender linings up front. It get's so filthy inside your fenders though, towards the door. I cleaned that up occasionally.
                    Really nice fitment though. Props. I love the body-colored I lip.
                    Do you plan on matching rocker panels and rear skirt?
                    Or Do you have plans of sourcing IS skirts?
                    You're so right. e36 M3 in an e3o shell. Fucking sick.
                    best modification to any car is a clean car.
                    -jeff
                    • e30polak
                      • 6136
                      #40
                      So now you know what traction is huh? :p
                      Lookin good Jasper! :woowoo:
                      INSTAGRAM: @UNDR8D_EMPIRE
                      • jahnaboi
                        • Oct 2006
                        • 1742
                        #41
                        Thanks man. You getting back into the scene or taking a different route?
                        Lol. I wish I had traction in first!!! These 245s are down to 3/32s. (wear bar).
                        Hopefully I could get my 17's on before saturday!!! Prepare to be pwndizzled!
                        • jahnaboi
                          • Oct 2006
                          • 1742
                          #42
                          Its wednesday (free day), and I've finished my two front lips. I guess I'll unveil what I've been working on.
                          These are pictures of the fronts BBS RS 17x8 ET35 for my e36 m3 5 lug.
                          These rims were a bitch to wetsand/polish as the lip folds in then out because of the offset.
                          The rears are being worked on after I post this. Hopefully I get these on by Saturday.
                          -Jasper
                          • ck_taft325is
                            • Sep 2007
                            • 6880
                            #43
                            Nice sand and polish job! 17x8 front and 17x9 rears? I probably missed the proposed specs... looks a-fucking-mazing. Great job and I'm excited about seeing them mounted up!
                            Need a part? PM me.
                            • jahnaboi
                              • Oct 2006
                              • 1742
                              #44
                              Yes 17x8 and 17x9 rears both e35. The centers haven't been sprayed yet, but that's the easy part. Anyone know the exact color of the original silver from the dealer that I could buy at autozone/kragen/paint store?
                              You can't believe how excited I am... but I'm also tired as hell. My shoulders are getting a work out.
                              • robrez
                                • Jul 2008
                                • 3376
                                #45
                                I got this info. from CactusJack, I'm pretty sure he wouldn't mind me sharing it.
                                The closest match to BBS bright silver is Acura, Vogue silver, code NH583M.
                                Get your paint & materials at Senik Paint, Costa Mesa. In rattle cans, Get 2 cans of primer, 2 cans of UPOL clear & then a pint of the Acura base coat (take the number, it is a Dupont #). If you want, they can put the Acura color in rattle cans for you - a pint makes 6-7 spray cans.
                                Strip - primer - sand 400 - base coat - clear coat
                                January 2012 COTM
